Welding vs. Bending - JeepForum.com
post #1 of 8 Old 09-26-2012, 03:08 PM Thread Starter
1995Moneypit
Welding vs. Bending
Preparing to start working on building off of a 94 YJ frame and would like to make new body mount brackets, axle truss, etc. Most of the "factory built" accessories like these are bent with a press brake. I don't have one (yet) and know that the look of these brackets are cleaner and I am assuming ultimately stronger. However, I would really like to fab my own parts. Should I have any concern with welding multiple pieces together to form a bracket, etc. in lieu of spending the money on a press brake? Or, any shame in it for that matter?
1995Moneypit is offline
post #2 of 8 Old 09-26-2012, 04:14 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
most factory piece are made from a single piece and are stamped. the reason for this is ease and speed. its alot quicker to take a flat sheet of metal and stamp out a body mount than it is for them to cut multiple pieces and weld them together.
there is no reason not to weld up a piece yourself IMO. cut out what you need and get to welding.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #3 of 8 Old 09-26-2012, 04:45 PM
tomjohn777
Two pieces of metal welded together "properly" are stronger than the steel is on it's own. BUT that means a full penetration weld without defects,I don't know how your welding skills are, But if you can weld I would say go for it! It will probably be plenty strong enough and you can say that you made it yourself.
tomjohn777 is offline
post #4 of 8 Old 09-26-2012, 04:55 PM
wushaw
Rockin jeep
wushaw's Avatar
You can also cut the material almost in two, bend it by hand and weld the gap, I have done this when I needed less than a 90deg bend in something.
wushaw is offline
post #5 of 8 Old 09-26-2012, 05:53 PM Thread Starter
1995Moneypit
Thanks for the input. I really enjoy making my own parts and one of the main reasons for my build (other than the fact that I'm tired of replacing rust on my current Jeep) is simply because I like working on stuff like this. I have a 220v AC/DC Lincoln stick that I feel comfortable with. I can weld, but I'm not going to insult the pro's out there by calling myself a welder.
post #6 of 8 Old 09-27-2012, 07:24 AM
firefighter315
Body mounts can also be easily cut from rectangle, box, or "C" channel. Just draw out what you need and cut away the rest. Then just drill them out with a hole saw and weld to the frame. Just another option to using a brake or cutting all three sides from plate and welding. Post up some pics and let us know what you come up with.
My YJ Build Thread
firefighter315 is offline
post #7 of 8 Old 09-29-2012, 11:59 PM
ltrail
1984 XJ Cherokee
I was thinking a piece of 2x2 .125 square cut at 45* angle there is the mount, no bending, no welding. Drill a hole and weld to frame. I'm all for building over buying, but if building you must be smart about not making extra work for yourself. Cutting 2 triangles and a square, plus prepping, and welding. A bit much when compared to one strategic cut.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #8 of 8 Old 09-30-2012, 04:47 AM
5-90
5-90's Avatar
1988 XJ Cherokee
That also means post-weld heat-treatment (to reduce the effects of the change in temper at the borders of the HAZ...)
Given a choice, I'll make forms to bend the metal around, then heat up the whole piece of metal and bend it. Fewer discontinuities, no HAZ, and simpler heat-treatment (since you just have to worry about work hardening instead of the HAZ and discontinuities.)
The HAZ decreases as the process advances - torch>stick>MIG>TIG - but you can't get away from it.
Mounts are bent because it is easier and cheaper to do so, just as screw threads are rolled because it is easier and cheaper to do so. This is a case where doing something the easy way gets you a better part (rolled threads are effectively cold-forged and the material compressed, while a cut thread is effectively a stress riser in the material.) In softer materials, you should use a thread forming tap instead of a thread cutting tape - same reasons.
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
Arc Welding - thinner rod or stitch welding attachment? rugsucka Fabrication Shop 17 12-20-2012 08:17 PM
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
Help with pipe bending ScJeepaholic Fabrication Shop 14 06-30-2009 09:53 PM
? about bending camjeep3 Fabrication Shop 13 01-27-2007 07:32 PM
Welding - full penetration vs. welding both sides Matt in TN Fabrication Shop 11 01-21-2006 07:03 PM
