Welding to a uni-body - JeepForum.com
post #1 of 18 Old 11-08-2011, 10:38 AM Thread Starter
Jason_alex
Hey guys,
Any advice for welding to a uni-body? I weld at work but I am use to thick ****... I am making rock rails for the 2001 Jeep Grand Cherokee and insted of drilling an tapping (to thin in my oppenion) I was thinking driving some nut inserts in and welding them in place. Any thoughts?
Thanks,
Jason
2001 Jeep Grand Cherokee Laredo 4.0L Selec-Trac 2.5" ROR lift
1977 Trans Am 400 bored 40 over new paint new sub-frame.
Jason_alex is offline
post #2 of 18 Old 11-08-2011, 11:02 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Nut-certs don't need to be welded. If it make you feel any better, a few light tack welds will be enough.
Most store bought rock rails are attached with self-threading bolts.
CJ7-Tim is offline
post #3 of 18 Old 11-08-2011, 12:58 PM Thread Starter
Jason_alex
Yea I have seen them with tap bolts but I really want these rock rails to have the beef behind them... I am going to go with 3/8 grade 8 bolts and attaching it with 3 kick plates on each side tubing is only 2x4" 1/4" wall
post #4 of 18 Old 11-08-2011, 01:31 PM
00JGC00
Properly installed nutserts should do the job. That's what I have on mine. Two were giving me grief so I put some tacks on them and that worked well. I also ran self-tapping screws through the pinch seam into the sliders.
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: http://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #5 of 18 Old 11-09-2011, 06:15 AM Thread Starter
Jason_alex
Most stuff I weld is 1" plus any special things to welding to a vehical with the pcm and computer stuff?
post #6 of 18 Old 11-09-2011, 07:27 AM
Jason
Disconnect the negative terminal of the battery. Obviously back the heat down a bit to prevent burn-thru. I've seen an article about welding unibodies, but it escapes me right now.
Jason is offline
post #7 of 18 Old 11-09-2011, 04:00 PM Thread Starter
Jason_alex
Lol I thought I wouldn't change my settings... and see what happens lol jk jk
post #8 of 18 Old 11-10-2011, 09:41 AM
AGDubyaJ
low voltage- low wire speed and dont burn through. sheet metal bolts secured properly to the uniframe will do just fine, just make sure to use some strong bolts on the pinch seam- grade 5 or better.
ill try to post some pics up of my WJ rock rails.
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #9 of 18 Old 11-10-2011, 12:48 PM Thread Starter
Jason_alex
I am trying to go without the pinch plate seam because I have the Laredo model and don't really want to get ride of the plastic.
post #10 of 18 Old 11-10-2011, 12:59 PM
smunns
Bolting them to the pinch seam gives them a lot more strength.
smunns is offline
post #11 of 18 Old 11-10-2011, 01:21 PM
MGDWJ
http://www.mallcrawlin.com/forum/sho...-Welding-Bible
MGDWJ is offline
post #12 of 18 Old 11-10-2011, 07:38 PM
AGDubyaJ
x2, even if you do decide to weld them on, you should still bolt them to the pinch seam.
AGDubyaJ is offline
post #13 of 18 Old 11-11-2011, 06:51 AM Thread Starter
Jason_alex
I am only thinking about welding the nut-certs on to the frame to bolt to..... is there any way to get around the pinch plate seam and still gain the strength?
post #14 of 18 Old 11-11-2011, 08:52 AM
webdog
1990 XJ Cherokee
Problem is the pinch seam gives the sliders up and down support. The way I look at sliders is a lever effect and the pinch seam is the fulcrum, there is usually not a hole ton of pressure on the frame as the pinch seam holds most the up and down force.
Without attaching it to the pinch seam you will probably end up having them sag and you might run into issues of the sliders legs pushing though it. As the pinch seam spreads the load out over the length of the slider.
webdog is offline
post #15 of 18 Old 11-11-2011, 11:37 PM
dodger889
Also ground as close to the welding area too.
A 89 yj with a 4.0 aw4 sye out of an 92xj. Now the hard part is done time to get it up in the air just a bit. Working on 8.8 with 3.73 and lsd for the rear. and new D30 hp with 3.73 .
For those who have not figured this out I'm old school but can handle the new too.
Originally Posted by bigsquat View Post
im just cheap, and cheap makes you creative.
dodger889 is offline
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
welding new body mount dustinnice Fabrication Shop 2 01-30-2010 08:58 PM
What is best setting for welding body panels Fastbeeatch General Jeep & Off-Road Equipment 9 08-06-2008 07:03 PM
welding on body what to disconnect 97_tj Fabrication Shop 16 12-23-2006 06:11 PM
2" Body Lift....welding?? Plink Tires & Wheels 3 07-22-2002 04:41 PM
