Welding table pics... - JeepForum.com
post #1 of 38 Old 12-19-2012, 07:24 AM Thread Starter
zboss86
Lets see some pics of those welding tables. I like to see what people have done to make their projects easier.
I saw this one ealier, http://www.jeepforum.com/forum/f37/w...oject-1451797/...
This one is more of a fab table than a welding table. I got tired of cutting tubing on the floor. The sander swings out of the way for longer pieces. Welded a socket to the clamp so I could open close it with a speed wrench. It works well. I'd like to make a table that with multiple clamping locations.
Cleaning out the garage... check what I have for sale here:
http://midsouthjeeps.com/forum/index.php?/topic/20693-jeep-parts-for-saletradebumper-2-spacers-relocation-brackets/
zboss86 is offline
post #2 of 38 Old 12-20-2012, 09:00 AM
Jim1611
Jim1611's Avatar
Here's mine. It's made from a scrapped machine table top of some kind. The top is 1 1/4" thick with bracing underneath and sits on 4" square legs. It weighs close to a ton.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #3 of 38 Old 12-20-2012, 10:46 AM
firefighter315
How much for shipping to Ky?
My YJ Build Thread
firefighter315 is offline
post #4 of 38 Old 12-21-2012, 08:53 AM Thread Starter
zboss86
Wow, I don't have a forklift to move that baby!
zboss86 is offline
post #5 of 38 Old 12-22-2012, 07:02 AM
tangotag
Here is one I built for limited space but still portable. Receiver hitch front and back for securing the table to the wall and the other for vice, 2' sheet metal bender, joint jigger etc.
tangotag is offline
post #6 of 38 Old 12-22-2012, 07:49 AM Thread Starter
zboss86
I like the idea of being able to fastening it to the wall. That'll be added to the list...
zboss86 is offline
post #7 of 38 Old 12-31-2012, 06:37 PM
KMD
1976 CJ7
Mines always full of crap. Posted pics on here somewhere. Bigger shop now I really need a bigger table.
KMD is offline
post #8 of 38 Old 01-01-2013, 11:23 AM
Jevy
zboss I really need a set up like that. Would you mind sharing the dimensions??? That would be perfect for me.
My '84 CJ7
Thread
My M416 with Roof Top Tent
Thread
Jevy is offline
post #9 of 38 Old 01-01-2013, 11:37 AM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Here is a double-duty welding table I built recently. It has a 3' by 6', 1/2" steel top, 4x4x3/16" legs and 2x4x3/16" and 2x3x3/16" rails and supports, all sitting on 6" dual-locking casters. Since I also do a lot of wookworking I needed a bench with a wood surface as well, so I also build a 1.5" maple overlay edged in oak which fits over the steel surface. It is a bit overkill as it weights close to 1000 pounds, but it is definately sturdy.
Welding Table - 5-12-2012 045.jpg   Welding Table - 5-12-2012 119.jpg   Welding Table - 5-12-2012 173.jpg
NashvilleTJ is offline
post #10 of 38 Old 01-01-2013, 10:12 PM
firefighter315
Very nice work Nashville!!
My YJ Build Thread
post #11 of 38 Old 01-04-2013, 07:11 AM Thread Starter
zboss86
Yeah, that's nice... You got some dough tied up in metal. I like the wood top also, almost to nice to work on. Proctects that 1/2" steel plate huh?
zboss86 is offline
post #12 of 38 Old 01-04-2013, 08:07 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
My table is buried in here somewhere..
Simple half sheet of 1/4" with 2x2x1/4" angle iron legs and ribbing.
BESRK is offline
post #13 of 38 Old 01-04-2013, 10:56 AM
firefighter315
Is that a jig for frame rail ends you have welded down to it?
My YJ Build Thread
post #14 of 38 Old 01-04-2013, 11:38 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
No.. it's actually a pair of 2x4 stubs that serve to hold a bumper in place for grinding the ends smooth.. allows me to flip them over easily.
In the upper left corner, you can see a little of my other "fixture".. it's a rotating stand that holds the bumpers while I weld them up. Allows me to easily spin a bumper around 360deg for quick welding.
For "bumper building", I have actual pieces of Jeep frames that I use.. YJ front/rear, TJ front/rear, CJ front rear, JK front/rear, and a XJ front. Picked 'em up over the years...
BESRK is offline
post #15 of 38 Old 01-08-2013, 04:42 AM
shortgoroper
1983 CJ7
I build this table. I went with a 4x6 top 1/2 in thick. The plasma chute works great. One modification was that I used a 30 gal steel barrel instead of fabricating square chute.
Its a very stable table.
http://www.millerwelds.com/interests...welding-table/
shortgoroper is offline
