welding rod codes - JeepForum.com
post #1 of 3 Old 02-14-2011, 01:36 PM Thread Starter
SGTCornewell
2002 KJ Liberty
welding rod codes
ok, searched and didnt find anything here. google only gave some info, but not enough to curb my curiosity. what does the code system in welding rods break down into? im planning on making "trail welding kit" and like to be as informed as possible when making any decision. when i was an electrician i could order any wire by knowing the amp draw. when i worked in water filtration i could order almost any fitting by part number because i knew how to read the code. i know you professional welders and fabricators have this stuff memorized and can dump truck info in your sleep on this subject. please enlighten me as im a to stick welding.
SGTCornewell is offline
post #2 of 3 Old 02-14-2011, 01:53 PM
Wintermute
1967 FSJ Gladiator
http://www.red-d-arc.com/pdf/Welding...ifications.pdf
"No man's knowledge here can go beyond his experience." - John Locke
"Vi Et Armis" - Cicero
Wintermute is offline
post #3 of 3 Old 02-14-2011, 04:18 PM Thread Starter
SGTCornewell
2002 KJ Liberty
that is exactly what i have been looking for!
edit: so, from what im reading, an E6010M or E6011M rod may be a good choice for battery powered trail welding due to it needing lower DC amps to weld and deep penetration. if anyone has any input positive or negative, please share it.
Arc Welding - thinner rod or stitch welding attachment? rugsucka Fabrication Shop 17 12-20-2012 09:17 PM
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-12-2011 12:48 AM
Welding 101 GilNewJeeper Fabrication Shop 5 04-15-2010 11:17 PM
welding the 8.8 grandman97 Engines & Drivetrain 6 09-11-2006 10:18 AM
Welding - full penetration vs. welding both sides Matt in TN Fabrication Shop 11 01-21-2006 08:03 PM
