Welding novice- professional grinder. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Welding novice- professional grinder.
Spartan Locker's at all time LOW exclusive from ROCKRIDGE FS: Jeep Fog Light LED Bulbs! Several Brightness Options! Bds fox ipf 2.0 racing series shocks now available at rock
Unread 05-15-2015, 12:21 AM   #1
IRQVET
1967 CJ5
As far as welding goes, I suck. No really, my welds look like they were done by Stevie Wonder, if only he developed the steady hands of a parkinson's patient just before the trigger is pulled.
I've been welding for about 3 months, using a cheap 110v reconditioned flux core machine. My neighbor has a really nice Miller mig machine, and his welds are so much stronger and cleaner that mine. Which makes me wonder, does a 110v machines produce a weaker weld than its 220v counterpart?
67 Dauntless CJ5- Seņor Money Pit
1998 Chevy Tahoe, 2D, 4WD, 2 in. lift, 33' Duratracs
IRQVET is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 11:51 AM   #2
RebelRider
Are both of the machines using shield gas?
RebelRider is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 05:43 PM   #3
underpowered
Bouncin' on a Budget
underpowered's Avatar
you are comparing apples to bananas here.
in general, yes a 220v is capable of a stronger weld than a 110v machine, but on thinner material, less than 3/16" thick, both will create sufficient welds. most 110V machines are not rated to do a single pass weld on material greater than 3/16"
Gas vs no gas, Flux core burns hotter than a MIG setup but usually results in a less desirable looking weld. Practice comes into play, as does prep work when welding as to how the end product comes out. and yes, a good machine helps, a HF welder will not give a pretty weld every time as it is simply not as consistent as a better machine. But it is capable of good welds still.
1998 ZJ-- lowered a touch
2000 powerjoke tow pig
Anti-jeep--1989 K5 blazer. the new off road ride
underpowered is offline   Reply With Quote Quick reply to this message
Unread 05-15-2015, 09:16 PM   #4
IRQVET
1967 CJ5
His does, mine does not.
Unread 05-15-2015, 11:03 PM   #5
1989comanche
1989 MJ Comanche
Check your polarity to make sure you are hooked up correctly, how much stick out are you running? Get a few pictures of your welds we can probably give you some tips to get better results.
1989 Comanche
Mostly stock except homemade custom bumpers
1989comanche is online now   Reply With Quote Quick reply to this message
Unread 05-16-2015, 06:55 AM   #6
Bobby6319
I had a century 220 volt and I just bought a Lincoln and there is a big difference in the welds mainly just more consistent and and I use to weld in a fab shop
Bobby6319 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 05:33 PM   #7
jnsm
1973 CJ5
It has to do less about the incoming power and more about the quality of machine if all other variables are the same, like shielding gas, polarity (gmaw is dcep and fcaw can be either dcep or dcen depends on wire) type wire size wire etc. The strength technically will be the same if done properly, the wire and base metal will dictate strength.
jnsm is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 08:53 PM   #8
glenn-91YJ
glenn-91YJ's Avatar
A "cheap" (HF) 110V flux core will never compare to a quality (Miller/Lincoln/Hobart) 220V gas MIG...end of story! The rest is up to you.
Owning a "Renegade" means being "Different"!
glenn-91YJ is online now   Reply With Quote Quick reply to this message
