Welding machine in jeep - JeepForum.com
post #1 of 11 Old 10-25-2013, 09:08 AM Thread Starter
Lincolnwelding
I posted this in the photo request section but never got a response so im trying here. Is anyone running any type of welder out of their jeep? I really want to get a buzzbox or a little mig machine and hook it up to my jeep but im not sure how. I want to avoid buying a generator but im well aware of how much power a good weld will require and doubt i can do that.
"Piper, theres a big difference between wingin it, and seeing what happens"
Want to change my forum name to jeep wheelikers
WJC #292
Lincolnwelding is offline
post #2 of 11 Old 10-25-2013, 09:22 AM
wgirvine
1992 XJ Cherokee
So you want to put a welder in your Jeep, but you don't want a generator. What power source are you planning on using to run the welder?
The road goes on forever, the party never ends....
wgirvine is offline
post #3 of 11 Old 10-25-2013, 10:25 AM Thread Starter
Lincolnwelding
I was hoping to see if i could convert it from my jeep if i was just gunna run a little mig. Like i said though i was pretty sure that wasnt going to happen the first time i had the thought of running a welder in my jeep. If i absolutley need a generator then thats what i need but if theres a way to run it off my jeep i would rather do that.
I really just want to see if any one has a running welder in their jeep period. Dont care how its run or what kind of welder it is or any of that. Do i have a preference of it being a more simple, cost effective set up? Yeah of course, but i'll also be happy to see the most confusing expensive set up ive ever seen in my life.
WJC #292
post #4 of 11 Old 10-25-2013, 12:20 PM
Ironworker709
Ironworker709's Avatar
This might be a good read and option for you...
How to: Make a Trail Mig (Flux Core) welder - JeepForum.com
Here is another option for emergency trail welding...
SERIOUS On Board Welder (OBW) If You Are Interested... - JeepForum.com
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #5 of 11 Old 10-25-2013, 12:23 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I have a "Premier Power Welder" setup. Currently, I need to replace the voltage regulator and install the hand throttle. The PPW is basically a stick welder, but also serves as a 110v power source (capable of running a 4.5" grinder).
I've used my welder to make many trail repairs with no problem. I think you can also hook up the "Ready Welder" (wire feed) to it.
BESRK is offline
post #6 of 11 Old 10-25-2013, 03:32 PM Thread Starter
Lincolnwelding
Well the PPW is nice but that thing is super expensive. Im going with the idea of gutting the little 90. Seems like a fun and productive little project.
WJC #292
post #7 of 11 Old 10-28-2013, 06:45 PM
andrewmacc
I find it an incredibly sketchy deal, but a friend of mine (yes a little bit of hearsay) was telling me about a certain style of alternator you can rig up to temporarily turn it into a welder, and then turn back into your working vehicle alternator when you're done. Frankly sounds like it would wreak havoc on your truck but it's been done before apparently.
"Chilton's and Haynes are for brake jobs, oil changes and starting campfires." - CJ7-Tim
'98 2dr/5spd Cherokee rockin' on tons, 5.9L V8 Magnum, HP60/14b, 5.13:1, locked, 14" coilovers, Dana 300 4:1 twin stick... oink oink!
andrewmacc is offline
post #8 of 11 Old 10-29-2013, 07:00 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've seen a few threads over the years.. where folks have taken a large case alternator and turned it into a welder.
For the occasional trail repair, it may be easier/cheaper to just use 2 batteries for welding.
BESRK is offline
post #9 of 11 Old 10-29-2013, 10:45 AM
sherlocktk
Im the guy who initially did the How to: Make a Trail Mig (Flux Core) welder - JeepForum.com. Mine still works good thankfully I dont need it often. I wish I was able to make the box a bit smaller, but done and a little large is better than an idea and not being used. The main reason for this vs stick. Is I am not good at stick welding as I have only done it once (not having a stick welder)
sherlocktk is offline
post #10 of 11 Old 10-29-2013, 10:52 AM Thread Starter
Lincolnwelding
Thanks for the write up on that! Im actually a certified stick welder (for about one more month) so i would be much more at home with stick but im not smart enough to learn how to gut a stick machine and reassemble it in working manor. Plus, i would imagine a stick machine that would be able to run hot enough for repairs would be pretty heavy.
WJC #292
post #11 of 11 Old 10-29-2013, 11:38 AM
theksmith
2003 WJ
you just need jumper-cables, 2 or 3 batteries, and another jumper wire or second set of jumper-cables and you can weld stick in an emergency. not for a long time, but it will fix most trail issues.
i just finished setting up a modular jumper-cable and trail welder kit myself: http://offroadpassport.com/forum/showthread.php?t=3114 - i should probably post it here too.
theksmith is offline
