Welding in the LA area? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Welding in the LA area?
PANDEMIC-USA 50" Double row LED LIGHT BAR!! These thiANOTHER Rockridge4wd Creation!! Spare Tire Carrier Delete The Jeep Forum Discount is ON!
Unread 05-03-2015, 12:38 PM   #1
KG6KJS
KG6KJS's Avatar
Hello,
Anyone a welder or know a good welder in my area? I am in Glendora, Ca
I need to have my LJ front control arm brackets replaced
Also need front & rear LJ control arm skids installed.
Also need front bumper brackets fabricated on a JK, the factory brackets have been cut off and I need the brackets to mount a winch bumper.
thanks, Chris
KG6KJS is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 11:18 AM   #2
cojab
I'm not from that area any more (thank God) and I don't have a specific recommendation, but since you've had no replies I guess I would just say yellow pages, google search, craigslist or check with some local 4wd shops and clubs.
I know when I lived/worked out there, there were plenty of mobile welders running around working oilfields etc.
cojab is offline   Reply With Quote Quick reply to this message
Unread 05-08-2015, 07:08 PM   #3
KG6KJS
KG6KJS's Avatar
Hello, Thanks. I hit up a few local shops but they all want to do big projects or they are unsure about welding on axles. Guess my money is no good around here. lol
Unread 05-16-2015, 11:03 PM   #4
Frank399
I need stuff welded also. Bump
[URL="http://www.jeepforum.com/forum/f22/franks-jku-obsidian-build-aka-savvy-2012-test-mule-2826194/"]Jeep Build Up <--Click Here[/URL]
Frank399 is offline   Reply With Quote Quick reply to this message
Unread 05-20-2015, 05:44 PM   #5
jnsm
1973 CJ5
To bad you aren't closer, I'd consider it. I'm out in the IE, on the east side of Redlands. I have welded on axle tubes and some on here may say it's a bad idea but if you use the correct filler and watch heat input it's not that bad. Been welding professionally (certified) since 92, on all kinds of stuff from high pressure gas to frame cracks on equipment.
jnsm is offline   Reply With Quote Quick reply to this message
