Welding - full penetration vs. welding both sides - JeepForum.com
post #1 of 12 Old 01-20-2006, 06:31 AM Thread Starter
Matt in TN
1979 CJ7
Which is stronger, or does it make a difference? I bevel both sides on thicker stuff (say 1/4") where I can't get full penetration, run very slowly with slow wire speed and as hot as I can to penetrate as much as possible, but still come back and weld the opposing side as I never get full penetration (I only have a 110V welder). Unfortunately, buying a 3-phase true MIG is out of the question right now
Is there a major drawback to welding both sides (making the weld brittle)? I know on our steel natural gas pipelines (0.188" - 0.312" wall) they use stick welders and lay a root bead with two filler beads on top of that, so multiple beads can't be THAT bad, can they?
Join an off-road club! http://www.cumberlandoffroad.com
'79 CJ-7, 304, T-18a, Dana 20, AMC-20 w/ Yukon 1-piece axles, and Dana-30, 33x12.50x15, 1" Body Lift w/ heavily trimmed fenders, full cage with seats and harnesses, CJ/Wagoneer power steering upgrade, custom front and rear bumpers, body armor, and belly-up skidplate
In the garage, waiting for hell to freeze over so I can finish the installation: Waggy front D44, AMC M23 rear
Matt in TN is offline
post #2 of 12 Old 01-20-2006, 07:37 AM
Down&Dirty
Down&Dirty's Avatar
When properly done, you can lay many more than 3 beads and not be a bad thing. With a 110 machine and beveling you should be able to get full penetration. I would suggest picking up a welding handbook from HD or Lowes and reading up. Welding on both sides is not a bad thing at all. I usually try to weld both sides of something.
53 willys wagon with less of rust and no more bugs. Now sporting a 1988 wagoneer frame, amc 360, dana 44's.
'80 CJ-5, full width, 3 link front, 1/4 elliptical rear, 38's, and propane.
Down&Dirty is offline
post #3 of 12 Old 01-20-2006, 07:53 AM
Mudinyeri
Mudinyeri's Avatar
I can't say that I've ever beveled both sides of a joint nor can I see how doing so would give you better penetration or make the weld stronger. You could certainly weld both sides, though. I'd probably run a single bead on the beveled side then stitch weld the flat side then come back and run your additional beads (I agree with being able to run more than three) on the beveled side. Of course all that depends on the type of weld and the application for the 1/4" steel piece.
Great minds discuss ideas; Average minds discuss events; Small minds discuss people.
Eleanor Roosevelt
Mudinyeri is offline
post #4 of 12 Old 01-20-2006, 12:14 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Keep your wire speed up. Voltage is controlled by the wire speed. The extra voltage will help your penetration and tie in.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #5 of 12 Old 01-20-2006, 12:24 PM
blake989
a full penetration weld means that there is physically a gap between the two pieces to be joined with a backing plate, the gap width is a function of piece thickness, one side of the joint to be welded is usually bevelled for electrode access, the angle of bevel is dependent upon type of welding process to be used, then the gap, bevel, and joint thickness is completely filled with weld material (multiple passes usually req'd). When done correctly, a full penetration weld as described above is stronger than the material joined.
The YJ is no longer my DD. I have sacrificed all future retirement plans for jeep parts. I'm depending on social security!
blake989 is offline
post #6 of 12 Old 01-20-2006, 02:15 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
1/4" is about the upper limit for a 110V welder. I'd just completely bevel (at about 45 degrees) one side of the joint and fill with a weave. That'll help keep from piling weld up at the joint. Any thicker than 1/4" and I think the metal sinks away (absorbs) too much heat for a 110V welder to be effective.
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline
post #7 of 12 Old 01-20-2006, 03:27 PM
o3bluetj
I agree with Besrk,but i would run a stringer bead for the root and cap with a weave with a 110 welder on 1/4"
o3bluetj is offline
post #8 of 12 Old 01-20-2006, 10:15 PM
speedracer2536
i have a question as well i have acess to a hobart mig welder but not a stick welder and would i be alright building a rear bumper with a swingaway and a recovery point or do i need to use a arc.
93 yj lifted locked and ready to rock
6.5"soa 35's lockers beadlocks,8.8
and some other junk here and there
www.krawltex.com
if your in austin look them up best guys to deal with hands down
speedracer2536 is offline
post #9 of 12 Old 01-21-2006, 07:54 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
A mig is fine. It would be nice if the welder was 220V.. it would burn in everything easy. If it's 110V, you might want to think twice about doing the thick clevis mounts. Otherwise, build it out of 3/16" stock and just bevel everything.
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline
post #10 of 12 Old 01-21-2006, 03:25 PM
hoytheld
Always remember...a couple tricks for doing 1/4" and thicker material with a 110vac unit:
As mentioned before....taper the meeting edges....this is kind of like when you glue two pieces of wood together with good wood glue...the wood will break beside the glue line 9 times out of 10....the weld is stronger than the steel you are putting it on....remember not to cool the weld in water...this tempers the weld and steel...let it cool naturally.
Also...if you have 1/4" and thicker...simply heat both pieces up with a torch before you weld....you will see a big difference on penetration
I wouldn't hesitate to weld 1" thick steel with a 110vac unit, if it was pre-heated, tapered, and a couple of passes....no problem
JH CUSTOMS MACHINE WORKS AND FABRICATION
Lathe and Mill Machine Work
Tig, Arc, and Mig Welding
Aluminum, Steel, Stainless, Titanium
jhweldfab.com
hoytheld is offline
post #11 of 12 Old 01-21-2006, 04:48 PM
o3bluetj
1"thick steel + 110v unit = hot glue gun
o3bluetj is offline
post #12 of 12 Old 01-21-2006, 07:03 PM
hoytheld
nah...It will work fine....follow the tips I said.....especially the pre heat...it will penetrate like a mo-fo!
and of course...multiple passes....I am not saying one pass....
jhweldfab.com
hoytheld is offline
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
New to welding... tank29 Fabrication Shop 19 03-20-2008 02:47 PM
welding the 8.8 grandman97 Engines & Drivetrain 6 09-11-2006 09:18 AM
Welding a Full Cage roll bar set up? TonysCJs Fabrication Shop 16 10-03-2004 06:50 AM
Welding dan240 General Jeep & Off-Road Equipment 12 03-27-2003 01:48 PM
