Welding Drag Link to Shorten it. - JeepForum.com
post #1 of 6 Old 03-04-2013, 07:47 PM Thread Starter
soonermatt
I needed to shorten a beefy WJ drag link for my YJ SOA / front stretch.
Everything went well but I needed to shorten it two inches further than it could go. I decided to cut and welded it. I cut 4x .25" x 2" slits in the end, turned my welder up all the way and my line speed down to nothing.
It might be the hottest weld I've ever burned. It's still glowing red in the picture a while after.
Do you think this should hold up?
soonermatt is offline
post #2 of 6 Old 03-04-2013, 07:51 PM Thread Starter
soonermatt
Better close up
post #3 of 6 Old 03-05-2013, 03:53 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Is one piece shoved into the other (telescoped)? If so, it'll probably be okay. Weld looks hot enough..
BESRK is offline
post #4 of 6 Old 03-05-2013, 06:48 PM Thread Starter
soonermatt
Yup it's telescopes about 4 inches.
I can't believe I got a response from possibly the most credible welder here.
Thanks!
post #5 of 6 Old 03-05-2013, 07:01 PM
Kettles
That is an interesting way to get weld surface area. It should hold up fine unless your bad enough you can make a good looking weld with no root fusion. But I don't think that is the case.
_=====o000o
//__l_l_,\____\,____
l_--\_l__l_/--|lllll|
_.(o)_)__.(o)_)--o-)_)
"Dee", a Patriot Blue 2001 Cherokee Sport 4.0L High-Output
"Live Free Or Die; Death Is Not The Worst of Evils." -General John Stark
Originally Posted by speedbucket View Post
perfect depends on how far away you are when you look at it:D
Originally Posted by Millermagic View Post
It's a 4.0 ... as long as there's something in the crank case that isn't coolant I'm sure it will still run forever.
Kettles is offline
post #6 of 6 Old 03-05-2013, 07:59 PM Thread Starter
soonermatt
Man I would NOT rule it out! I've done some bad welds in my short welding career. After reading a thread or two on Pirate and Classic Bronco I was a little afraid of this. I ground it down to fresh metal and had it prepped well. I was going so slow the outer sleeve was melting like warm butter under my puddle.
I really want to see how it looks inside but can't afford to lose the part for now.
The more I thought about it, this should be pretty strong. If it were to fail it should happen when I'm locked and going through trails at 5mph. Not on the highway. Others posted they have done the same and that it held up.
