Quantcast Welding cast-iron? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Welding cast-iron?
TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Old 12-18-2007, 02:20 AM   #1
HTOR
Welding cast-iron?
Suppose i wanted to weld a Carrier or Axle tube to housing,
what would be the best way of doing this?
If you can build it, i will break it.
Team Crazy, and Mr Diameter Custom Machine.
"More Balls than you can shake your nuts at."
Jeep 1: 2000 Jeep Wrangler Sport - Its got goodies:)
Jeep 2: 1995 Jeep Grand Chero Limited - Its gonna go fast.
HTOR is offline   Reply With Quote
Old 12-18-2007, 05:37 AM   #2
glenno
use a welder
Most opinions on this subject say it's a NO NO. If you heat up the cast it will weaken and crack. They say the cast needs to be heated to two or three hundred degrees in an oven before you should weld it. I don't really know. I did weld my axle tubes to my pumpkin on my old ford f-150 ten years ago before I knew it was a NO NO and I never had a problem. The truck has a dana 44 up front and I welded a solid bead all the way around. Would I do it again? Probably not. I've read that the factory welds are plenty strong so I wouldn't mess with them.
glenno is offline   Reply With Quote
Old 12-18-2007, 08:16 AM   #3
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Preheat the work to 200 degrees, weld using high nickel rod or ER-70S6, post heat to 150-200 degrees and bury the work in warm sand or wrap a welding blanket around it. You'll want it to cool as slowly as possible. I've done this to cast and nodular iron and I know that it works. Preheat and postheat are the key.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 12-18-2007, 10:48 AM   #4
JJs99TJ
here's a previous thread of welding axle tubes, it can be done:
http://www.jeepforum.com/forum/f37/tips-welding-axle-tubes-442479/
Originally Posted by rnemovr
oman, what happened in the wreck? i see it bent your bumper, did you hit a camel?
JJs99TJ is offline   Reply With Quote
Old 12-18-2007, 11:52 PM   #5
Ryanpowell167
When i weld cast i preheat and postheat but i leave out the nickel rod unless its something very important....That **** is 2 bucks a rod....
DARK STONE 2005 6.0l v-8 PowerStroke F-350
BLACK 1992 YJ 383Stroker, TH350, looking for a np205, d44 front, 12bolt rear, SOA on 4" springs, 35" Baja Claws, m8000, Electric fan, sliders, bumpers, crossmembers, all made by myself.
Black Jeep Club Member #167
Ryanpowell167 is offline   Reply With Quote
Old 12-19-2007, 08:01 AM   #6
MUDBUG J
The difference is that the diff pumpkin is cast steel, not cast iron. Cast steel can be welded much more successfully than cast iron.
MUDBUG J is offline   Reply With Quote
Old 12-19-2007, 08:19 AM   #7
Ryanpowell167
Depends on axle model. Not all are cast steel. Some are iron so are FORGED and some are alum....
Old 12-19-2007, 08:21 AM   #8
MUDBUG J
Thats true...my D44 is cast steel. Best to check to make sure.
Old 12-23-2007, 09:26 AM   #9
dblakley
use a torpedo heater to pre-post heat your work. backing it up slowly as the weld cools
dblakley is offline   Reply With Quote
Old 12-23-2007, 01:29 PM   #10
notmyj
Part of the Three Percent
notmyj's Avatar
Welded the tubes on my 8.8. Pre heat. Weld 90* then weld opposite. Repeat. I TIG'ed mine, with nickle rod. pre heat post heat. Let cool slowly.
www.pghoffroad.com
My SOA Build
Recovery Gear Basics
My BUDGET York OBA Install
Budget Welding Cart
Carling Contura Switch Panel
If it has tracks, tires or tits, its gonna cause a problem.
"Everytime someone installs a S35 kit or otherwise "upgrades" a D35, an angel looses its wings."
Originally Posted by Warren Zevon
Send lawyers, guns and money. The **** has hit the fan...
92, 4.0, AW4, 8.8, D30, 15x8, 35's, SOA etc, etc
92, 2.5, 30, 8.8, 4.88, Locked, Winch, 15x8, 35's, 3.5" (RIP)
notmyj is offline   Reply With Quote
Old 12-29-2007, 07:21 PM   #11
vtjeeps
umm
so best way to weld cast is with a tig or with a stick..
The insurance company said its high RISK but i said no no its full width ...
vtjeeps is offline   Reply With Quote
Old 12-29-2007, 08:08 PM   #12
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I've done it quite a few times with a regular mig too...
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 12-30-2007, 02:54 PM   #13
GreenJip
I am getting ready to weld up my 8.8 tubes to the housing also. How can I tell what metal the housing is made of. Anyone?
/l ,[____],
l---L -OlllllllO-
()_)-()_)-o-)_)
8.8 Swap: http://www.jeepforum.com/forum/f9/8-8-swap-into-tj-build-thread-501704/
GreenJip is offline   Reply With Quote
Old 12-30-2007, 03:09 PM   #14
Matt Gertsch
www.lp.org
Looks great, but you'll probably want to go in and fill the crater.
Roger Waters
Glock Forum
