Welding back side of interior roll cage - JeepForum.com
post #1 of 8 Old 07-30-2013, 12:25 AM Thread Starter
outbackmatt
Just a curiousity when you build an interior roll cage and properly fit it close to the body how do you weld the back side and furthermore how do you paint it?
outbackmatt is offline
post #2 of 8 Old 07-30-2013, 05:18 PM
tjcj
Pull the cage to weld the hard to reach spots and then paint it
Sent from my XT881 using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #3 of 8 Old 07-31-2013, 08:36 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
pulling the cage is not usually an option in something like an XJ if it a full interior cage..
to weld it, place a piece of sheet metal between it and the head liner to protect it.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #4 of 8 Old 07-31-2013, 08:59 PM
DualPurposeXJ
1994 XJ Cherokee
if you cant pull the cage out you can cut holes in the floor and drop the cage, something like this
If you're in control you're not going fast enough - parnelli jones
DualPurposeXJ is offline
post #5 of 8 Old 08-06-2013, 07:38 AM
COplayground
Dropping the cage inside the cab with access holes is really the only way to do it right. DualP is telling the truth
COplayground is offline
post #6 of 8 Old 08-06-2013, 09:22 PM
jaspepp
I getting ready to build a cage as well and had the same question. Anyone ever tried a little mirror ?
jaspepp is offline
post #7 of 8 Old 08-06-2013, 10:25 PM
COplayground
If you built a cage with tolerances large enough to fit your welder in behind to do the welds such as the A pillars or a windshield support bar. It would be horribly in the way visibility wise. The mirror is the least of your concerns, its trying not to light your interior on fire or burn the snot out of your paint. When it comes to cages there really is only one way to do it right, the rest is just garbage. Look into a sanctioned race rule book that is the best place to learn what is acceptable for roll cages. Safety is not a place to skimp!
post #8 of 8 Old 08-09-2013, 06:10 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I drop the cage thru the floor.
I've also done a couple cages where I tacked everything together, removed the main B piller hoop, layed the cage down, welded front stuff together, stood cage back up and finished welding B pillar. Normally though, I'd just bore holes in floor and drop cage down to weld on top and on sides.
BESRK is offline
