Welding Advice - Page 2 - JeepForum.com
post #16 of 118 Old 11-22-2010, 08:06 PM
wushaw
Rockin jeep
wushaw's Avatar
Practice, practice & practice...good beads will come.
Oh and patience.
wushaw is offline
post #17 of 118 Old 11-22-2010, 08:08 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
Originally Posted by little_Jeep View Post
Gas and a bigger welding machine really do help the newbie.... After welding with gas, I'll never weld without it as long as I can help it.
X2. welding with gas is 100X better than without.
i use .030 wire at home and a 75/25 mix. at work we use straight CO2 on .035 wire.
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #18 of 118 Old 11-22-2010, 08:17 PM
Kenbo-Slice
Oh and patience.
This ^. Nothing else needs to be said.
Welding is ridiculously easy, anyone can do it especially MIG / wire feed welding. Fabrication is FAR different from welding. The fabrication is the hard part.
Jeep build up...ONGOING
Kenbo-Slice is offline
post #19 of 118 Old 11-22-2010, 11:10 PM
4bangerYJ
I'd say that material is to thick for your machine. I use flux and a Lincoln 135. 3/16 is about the max I would do. I use the highest settings (G for heat and 3 for wire speed). Check in inside panel on the door to see what the settings should be set at for the thickness of your metal.
Flux is messy and requires you to chip it off, but it burns hotter than gas. Just get a wire wheel for your drill and it comes off pretty fast.
Also what size wire are your running? .035 or .030?
Find some 1/8 steel to practice on and adjust the heat/wire speed and like others have said practice,practice practice.
4bangerYJ is offline
post #20 of 118 Old 11-23-2010, 02:36 AM
Ironworker709
Ironworker709's Avatar
Good advice...
And just to clarify..MIG is "easier" to lay a "prettier bead",especialy on these 110v and 220v 180 amp or so machines..but a fluxcore is a hotter and stronger weldment with these small amp machines..it just takes getting used to gettin the "eye" in the difference between you're slag and metal puddle..
Slag will be what looks like water running..metal will have little ripples and you can see it starting to solidify,or freeze quicker than the slag,you just have to practice untill you can see the difference..that's one BIG mistake most beginners make when learning to weld,they just go at a constant speed to try n get a flat pretty weld,but what is needed is to see the penetration and fill of a weld puddle to make a correct clean strong weldment.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #21 of 118 Old 11-23-2010, 07:13 AM
jatepper
Originally Posted by badmatt View Post
Also Push the weld dont drag it you will get better penetration that will help flatten out the weld too.
I always thought pulling gives you a little deeper penetration????
1986 CJ7 Laredo - Auto 14k miles
1985 CJ7 Renegade - Auto 33k miles
1982 CJ8 Scrambler - T5 T-SPD
jatepper is offline
post #22 of 118 Old 11-23-2010, 07:21 AM
Ironworker709
That is Correct...Pushing gives it a flatter lay for a prettier weld..but pulling gives more penetration which equals more strength
Never forget 9/11
post #23 of 118 Old 11-23-2010, 12:14 PM
badmatt
1990 XJ Cherokee
you can do it either ways but ive always been instructed to push, and with flux core(which is what is what the OP used by the looks of it) I find pushing for me it works better for penetration.
heres a solid video to show you puddle control and torch movement.
YouTube - Mig Welding Technique Taught by Old Timer
badmatt is offline
post #24 of 118 Old 11-23-2010, 05:58 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
This..
I was going to suggest stepping down to 1/8" for practicing too..
For a consistent bead, it's all about being comfortable and being able to move along consistently. If need be, do a "dry run" with the gun to make sure you're comfortable along the whole bead path. If you're welding on a table, you should be able to find/provide lots of support for your forearms to minimize unwanted movment (read shaking).
BESRK is offline
post #25 of 118 Old 11-23-2010, 11:50 PM
Ironworker709
The OP is using a 110v machine with fluxcore....
It works better for you because it's a pretty weld,but pulling penetrates more,especialy with fluxcore where slag would be running in front of the puddle if you're pushing.
Never forget 9/11
post #26 of 118 Old 11-25-2010, 06:23 PM
rixcj
rixcj's Avatar
1979 CJ5
^^^ I agree ^^^ Pull flux core wire (as though you were stick welding), and push solid wire w/gas.
Also, the polarities are different between the two types of wires. Flux core uses DCEN and solid wire uses DCEP.
Rich
'79 CJ5, AMC 360, t-18/d20 twin stick, dana 30/amc20(Mosers), Edelbrock Performer intake, Holley 600, ps/pb, DUI HEI, 'glass tub/1pc. tilt nose, 33x12.50 BFG AT's.
There's a fine line between "hobby" and "mental illness".
rixcj is offline
post #27 of 118 Old 11-26-2010, 10:25 AM
jeepfreek383
"if it has slag your supposed to drag"
jeepfreek383 is offline
post #28 of 118 Old 11-27-2010, 08:51 AM
TBailey
1983 CJ7
The instructor I had in my two year vocational school taught us to always pull with wire feed process.
TBailey is offline
post #29 of 118 Old 11-27-2010, 08:55 AM
rixcj
rixcj's Avatar
1979 CJ5
You're only supposed to pull, or drag, when using flux core wire.
If you're using a gas shielding, you want to push the gun. This clears a path for you ( the gas removes the comtaminating oxygen ). The bead will also penetrate better, and lay flatter than if you dragged the gun.
Rich
rixcj is offline
post #30 of 118 Old 11-27-2010, 08:55 AM
Jim1611
Jim1611's Avatar
According to the video that came with my Miller mig welder pulling is what will give the best penetration. They recommend pushing on thinner materials where there's a danger of burning through. From what I've tried they are correct.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
Welding aluminum advice needed Jerry Bransford Fabrication Shop 21 09-14-2009 09:31 AM
Advice for auto-dimming welding mask? dougy147 Fabrication Shop 32 04-08-2009 08:15 PM
OMG i need welding advice!!! any interest?? j0nesy Fabrication Shop 57 12-13-2008 07:19 PM
Welding advice needed Cerealdaemon Fabrication Shop 5 10-05-2006 02:55 AM
