Welding Advice - JeepForum.com
post #1 of 118 Old 11-22-2010, 06:02 PM Thread Starter
jeepaholic91
Welding Advice
Please don't post on here if your going to make fun of me, but me and my buddy where laying some beeds and wanted to see what yall thought.
thanks
Louisiana Tech University
jeepaholic91 is offline
post #2 of 118 Old 11-22-2010, 06:12 PM
Area.3.Fiftyone
Not bad. I've seen way worse.
It's going to take some practice to get nice, even, uniform beads.
I'm pretty anal about aesthetics and even go as far as clamping a piece of angle iron to whatever I'm welding and then rest the head of the MIG against it while trying to keep the same distance away from the base metal while keeping a constant push/pull.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #3 of 118 Old 11-22-2010, 06:24 PM
Jim1611
Jim1611's Avatar
^^^As Stan said and you might need a little more heat. What kind of rod are you guys using? Keep practicing, you're getting there. And if anybody makes fun of you just remember they made welds that might not have been as good as yours. We all have to start somewhere!!
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #4 of 118 Old 11-22-2010, 06:30 PM
Area.3.Fiftyone
One thing that I forgot to mention:
I do not see any grinding marks on the material which leads me to believe that you didn't clean up the material prior to welding.
You will see a huge difference in weld quality once you get that coating off of the metal. Always use a grinder or a flap disc to get the material shiny before you weld and you'll see what I mean.
post #5 of 118 Old 11-22-2010, 07:04 PM
badmatt
1990 XJ Cherokee
slow down on the travel, and make C motions, little more heat as well. Also Push the weld dont drag it you will get better penetration that will help flatten out the weld too.
badmatt is offline
post #6 of 118 Old 11-22-2010, 07:09 PM Thread Starter
jeepaholic91
I'm not an very educated welder so i might not even be making sence right now, but it's a flux core welder. So I'm not using a rod.
It's a Lincoln 140 flux core/mig welder
Lincoln Electric Weld Pak 140 HD Wire Feed Welder - K2514-1 at The Home Depot
post #7 of 118 Old 11-22-2010, 07:16 PM
little_Jeep
I'm a fairly new welder want to be. I find that I have to slow my hand speed down. Weld metal scraps together, let them cool, then use a BFH (sledge hammer and driveway) to break them apart. If you can break the weld apart, you didn't do it correctly.
little_Jeep is offline
post #8 of 118 Old 11-22-2010, 07:21 PM Thread Starter
jeepaholic91
DUDE! That's exactly what we did haha
post #9 of 118 Old 11-22-2010, 07:28 PM
The_Blacksmith
1993 XJ Cherokee
you are staying in one spot too long which is why its building up and pooling, adjust the wire speed.
also it seems like your heat is too low as its not really flowing very well. hows the pressure on your gas?
The_Blacksmith is offline
post #10 of 118 Old 11-22-2010, 07:30 PM
little_Jeep
He isn't using gas....
post #11 of 118 Old 11-22-2010, 07:32 PM Thread Starter
jeepaholic91
post #12 of 118 Old 11-22-2010, 07:32 PM
underpowered
Bouncin' on a Budget
underpowered's Avatar
could use more heat for sure, as your bead did not seem to melt into the metal but more lay on top of it.
getting the motion down will take a while to keep it even and uniform through the weld.
and as said before prep work is everything. sure you can burn through rust and paint but you will get a much higher quality weld with clean metal. we all started somewhere, just keep practicing and working on it. they will improve!
1998 ZJ-- lowered a touch
2005 GMC 2500HD 496 C.I.
Fat Amy-1989 K5 blazer. Linked, lifted, 38.5's on won tons. Big Girls can play in the woods too.
underpowered is offline
post #13 of 118 Old 11-22-2010, 07:42 PM
Knothead2000TJ
I've got one of the little Lincoln 110v welders. Do yourself a favor & go ahead & buy the gas setup for it. Before buying the kit, I practiced a lot with the flux core wire, & never did get what I'd call a "clean" bead. With the gas (I use straight CO2 for mild steel) I can lay down some wicked clean beads. These little welders do a pretty good job. I'm hunting out of numerous treestands that I fabbed up myself.
Knothead2000TJ is offline
post #14 of 118 Old 11-22-2010, 07:45 PM
little_Jeep
Gas and a bigger welding machine really do help the newbie.... After welding with gas, I'll never weld without it as long as I can help it.
post #15 of 118 Old 11-22-2010, 07:53 PM
Knothead2000TJ
When I need to "really" weld something, I go up to the neighbor's shop. We've got a ESAB 300 amp MIG. We use "dual shield" (flux core .045 wire with shielding gas, too). It'll weld any thickness metal you can come up with. Only problem I have is I tend to weld too slow with it, after being use to my little Lincoln.
White 2000 Sahara with Spice soft top
Half doors w/glass sliders
4.0 w/auto
31x10.50 Cooper STT's on Canyons
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
Welding aluminum advice needed Jerry Bransford Fabrication Shop 21 09-14-2009 09:31 AM
Advice for auto-dimming welding mask? dougy147 Fabrication Shop 32 04-08-2009 08:15 PM
OMG i need welding advice!!! any interest?? j0nesy Fabrication Shop 57 12-13-2008 07:19 PM
Welding advice needed Cerealdaemon Fabrication Shop 5 10-05-2006 02:55 AM
