Welders read this!! It could save your life!! - Page 4 - JeepForum.com
 1Likes
post #46 of 63 Old 07-10-2013, 11:22 PM
WranglerRouser
Very useful info!
WranglerRouser is offline
post #47 of 63 Old 10-31-2013, 10:54 AM
Countdogula
A/C coolant will also turn to phosgene when burnt, just fyi.
Countdogula is offline
post #48 of 63 Old 11-17-2013, 05:00 PM
dellray
thank you
dellray is offline
post #49 of 63 Old 11-25-2013, 01:16 AM
outbackmatt
The ingredient in chlorinated brake cleaner that will react and create toxic phosgene gas is tetrachloroethylene.
I know a lot of people use white lithium grease to lube their tube benders as the tubing slides through. I am concerned after reading the liquid wrench msds.
I was shocked to see the main ingredient in Liquid Wrench White Lithium Grease is... tetrachloroethylene.
http://www.trcc.commnet.edu/Div_Admi...20Sec%2016.pdf
Why in this link for the exact same lithium grease is tetrachloethylene no where listed?
http://www.rscbrands.com/products/msds/L616.PDF
The warnings about brake cleaner have been widely posted but this is the same exact chemical hidden in white lithium grease. For years I have welded on tubing that had lithium grease on it and I am sure many people have too as it is such a commonly used lube for tube bending.
outbackmatt is offline
post #50 of 63 Old 02-13-2014, 06:41 PM
whiskeywiz
Just tagging to read later. Thanks
whiskeywiz is offline
post #51 of 63 Old 04-21-2014, 12:35 PM
Nitr0EngiEx
thanks for heads up !
Nitr0EngiEx is offline
post #52 of 63 Old 09-08-2014, 01:58 PM
rockymtwrangler
Phosgene is nasty stuff, the easiest way to remove light grease and oil from new steel is baking soda water and a wire brush then just sweep off and you're golden
rockymtwrangler is offline
post #53 of 63 Old 12-07-2014, 07:25 PM
badweatherbiker
not feeling well tonight guys, I made about 3 tack welds on a painted rack and apparently inhaled some fumes. didnt think it would be a big deal it took 30 seconds, everyone please b careful especially if you are new to welding like me
badweatherbiker is offline
post #54 of 63 Old 12-09-2014, 08:28 PM
HAFICON
Well I know not to use brake cleaner anymore... Anyone suggest something safe to clean the oily film off?
315/70/17 Duratrac on MB Wheels
AEV 2.5 with M.O.R.E 1" body lift
Viair 450c, ARB Air lockers,
4.88's and TNT truss.
My build thus far.
HAFICON is offline
post #55 of 63 Old 01-06-2015, 05:43 PM
xj800
Just for sake of welding knowledge, Don't ever torch cut aluminum. You have to plasma cut or blade cut aluminum because the temperature of the torch can evaporate the aluminum and kill you dead.
Not to be confused with aluminum torch welding, which the flame isn't hot enough to vaporize the aluminum into a poisonous gas.
xj800 is offline
post #56 of 63 Old 01-06-2015, 05:49 PM
xj800
Also, If you plan on welding on galvanized steel then you should set up a fan next to your work piece, metal fume fever is no fun but a glass of tall milk will ease the side affects. Galvanization makes a white powder once its burned but you can wipe that off with ease. Its the fumes that get your gut in knots. It wont kill you too fast but its not such a nice feeling.
xj800 is offline
post #57 of 63 Old 01-06-2015, 05:49 PM
xj800
Lastly!! If you burn your eyes put un cooked potato slices over them while you sleep, Its strange but it works!
xj800 is offline
post #58 of 63 Old 03-22-2015, 11:43 PM
Bigmaaty
1979 CJ7
Didn't see it it mentioned, but I keep a spray bottle with denatured alcohol in my garage for most of my easy cleaning. I use more potent stuff for some of the tuff cleaning but the alcohol is nicer to work with. Not as toxic as most other cleaners and it evaporates quickly with no residue.
Bigmaaty is offline
post #59 of 63 Old 03-30-2015, 08:16 AM
Jim1611
Jim1611's Avatar
I really like the metal cleaner that POR sells called Marine Clean. Mixes with water and it will do a great job of getting rid of grease. Just wear gloves because it is hard on your skin. Purple Power and Simple Green work too.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #60 of 63 Old 08-26-2015, 05:36 PM
revrnd
Originally Posted by Shmee View Post
I confirm about galvanized steel. I used to work in an elevator shop and weld that a lot with no aspiration system and had to quit before 1 year for health purpose order of my doctor, started having symptomes
after few month ,same for the guy who was working with me and the previous welder who worked there for over 6 year died.
At my workplace the welders would be livid if you brought anything galvanized into the shop.
revrnd is offline
Arc Welding - thinner rod or stitch welding attachment? rugsucka Fabrication Shop 17 12-20-2012 08:17 PM
First welding projects: welding cart and rock sliders johnsoninc86 Fabrication Shop 13 12-11-2011 11:48 PM
brake cleaner problem (welding) attackcammel Fabrication Shop 31 10-12-2011 01:43 PM
engine cleaner / valvetrain cleaner? BNovak Engines & Drivetrain 8 02-14-2007 05:44 PM
Welding - full penetration vs. welding both sides Matt in TN Fabrication Shop 11 01-21-2006 07:03 PM
