Welders read this!! It could save your life!! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Welders read this!! It could save your life!!
Super Low Prices on TJ Bumpers and $399.95 Tire Carriers!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineGenright at JeepHut
Unread 10-07-2011, 01:57 PM   #1
AmbuGrl
AmbuGrl's Avatar
http://www.brewracingframes.com/id75.htm
Here's an article on it...
The short of it is, it turns into a poisonous gas that can kill you quick
- HM1(SW/AW)Ret USN Dec 23,1992 to Dec 31, 2012
I drive an XJ, and all of my power windows work :)
DD (Mine) - 98 XJ Moss Green
(His) - 92 YJ
Sold - 95 ZJ
Sold - 97 XJ Red
Sold - 98 XJ
USN Jeep Club Hull #36
NAXJA #3700
Originally Posted by RacerX View Post
WTF is Clockspring??? my Jeep has digital clock
AmbuGrl is offline   Reply With Quote
Unread 10-07-2011, 02:19 PM   #2
Netpackrat
Thanks for making this a sticky. Here are a couple previous threads on the topic with a lot of good info:
http://www.jeepforum.com/forum/f37/s...lding-1012133/
http://www.jeepforum.com/forum/f37/b...lding-1273715/
Netpackrat is offline   Reply With Quote
Unread 10-07-2011, 02:50 PM   #3
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Phosgene.... Mmmmm....
Bad thing is.. prior to a couple years ago, I wouldn't have given it a second thought.. and actually welded areas that had been "degreased" with brake cleaner.. it smelled horrible..
Glad I know better now..
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Unread 10-07-2011, 03:40 PM   #4
athos76
Glad to see something I posted is useful, for once...
2006 I6 6-Speed X, 33" Goodyear Duratrac, RC 3.25" lift, Windstar CAI, York OBA (in progress), custom corner guards (in progress)
Stupidity is NOT a crime... therefore you're free to go.
Support STU-OFFROAD NOW!!!
athos76 is offline   Reply With Quote
Unread 10-10-2011, 11:55 PM   #5
04WJny
1987 YJ Wrangler
wow never would have known that. thanks for the post
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
[CENTER][URL="http://www.jeepforum.com/forum/f22/sloooooow-blue-yj-build-1234350/"]My YJ Build[/URL][/CENTER]
04WJny is offline   Reply With Quote
Unread 10-11-2011, 01:11 AM   #6
04WJny
1987 YJ Wrangler
Just found this govt article about some welding material warnings, includes phosgene as talked about in the article that AmbuGrl posted: http://www.osha.gov/doc/outreachtrai.../weldhlth.html
Also the zinc coating in galvanized steel can be toxic as well, its always important to check the MSDS for each material you are going to weld
2004 WJ I6 4.0L DD
Unread 10-24-2011, 04:20 PM   #7
Shmee
I confirm about galvanized steel. I used to work in an elevator shop and weld that a lot with no aspiration system and had to quit before 1 year for health purpose order of my doctor, started having symptomes
after few month ,same for the guy who was working with me and the previous welder who worked there for over 6 year died.
Shmee is offline   Reply With Quote
Unread 10-25-2011, 06:55 AM   #8
Skytard
Oh my god. This must be a warning sign from the Gods. I was littlerally about to go pick up some break cleaner to clean off the oil on some tube I was welding on for my job. Thanks for posting this, it may have saved my life!
Poor college student.
Skytard is offline   Reply With Quote
Unread 10-27-2011, 08:24 PM   #9
Hotshot
I fixed my own jeep
Hotshot's Avatar
I've used brake cleaner, degreaser, and whatever was handy in the shed to clean that oil film off steel. I'll never do it again. Thanks for this post, I'm going to pass this info on to some friends.
Hotshot is offline   Reply With Quote
Unread 10-27-2011, 08:32 PM   #10
SamPsychoWise
Steel Oncologist
SamPsychoWise's Avatar
I fought with my job for a year before they would give me a resporator. Also once a year I take a Pulmonary function test. Job required for people who use a resporator.
Good looking out!
SamPsychoWise is offline   Reply With Quote
Unread 10-27-2011, 08:35 PM   #11
iced98lx
If you don't have a ventilation system (down draft or up draft tables) to weld on, or items are too big always be aware of what you're welding and what has been put on it!!
iced98lx is offline   Reply With Quote
Unread 11-03-2011, 08:25 AM   #12
TJRHD
wow
Don't look at my work too close or too long..
My thread redo
http://www.jeepforum.com/forum/f22/yes-i-know-im-wrong-side-crazy-thread-redux-1484068/
TJRHD is offline   Reply With Quote
Unread 12-01-2011, 07:33 PM   #13
Motorcharge
SWANSON 2016
Motorcharge's Avatar
1992 XJ Cherokee
Odd, I thought this was common knowledge for shops. Came up in one of the safety videos at work when I started at the dealership I work at.
Project Motörcharge | XJ Non-Tech FAQ | Ammo Can Lock Box | Rear Bumper Build | Front Bumper Build | Pre-95 GC-XJ Seat Swap | Motorcycle Build
Under my tutelage, you will grow from boys to men. From men into gladiators. And from gladiators into Swansons.
WANTED: Decent condition MJ tailgate - PM for details.
If you find my post to be good or helpful please take a second to click the "thumbs up" icon near the quote option. Thank you.
Motorcharge is offline   Reply With Quote
Unread 12-01-2011, 10:57 PM   #14
2doorxj
2doorxj's Avatar
Im guessing a chlorine free brake cleaner would be a better substitute?
2012 Cherokee of the Year
2doorxj is offline   Reply With Quote
Unread 12-31-2011, 03:52 PM   #15
RenoF250
I doubt it, it has pretty nasty stuff in it as well. I always though brake cleaner left no residue. I think I electronic contact cleaner leaves no residue but I would not bet on it.
RenoF250 is offline   Reply With Quote
