-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   Welders read this!! It could save your life!! (http://www.jeepforum.com/forum/f37/welders-read-could-save-your-life-1274041/)
AmbuGrl 10-07-2011 01:57 PM
http://www.brewracingframes.com/safe...sgene-gas.html
Here's an article on it...
The short of it is, it turns into a poisonous gas that can kill you quick
Netpackrat 10-07-2011 02:19 PM
Thanks for making this a sticky. Here are a couple previous threads on the topic with a lot of good info:
http://www.jeepforum.com/forum/f37/s...lding-1012133/
http://www.jeepforum.com/forum/f37/b...lding-1273715/
BESRK 10-07-2011 02:50 PM
Phosgene.... Mmmmm....
Bad thing is.. prior to a couple years ago, I wouldn't have given it a second thought.. and actually welded areas that had been "degreased" with brake cleaner.. it smelled horrible..
Glad I know better now..:cheers2:
athos76 10-07-2011 03:40 PM
Glad to see something I posted is useful, for once... :D
04WJny 10-10-2011 11:55 PM
wow never would have known that. thanks for the post :2thumbsup:
04WJny 10-11-2011 01:11 AM
Just found this govt article about some welding material warnings, includes phosgene as talked about in the article that AmbuGrl posted: http://www.osha.gov/doc/outreachtrai.../weldhlth.html
Also the zinc coating in galvanized steel can be toxic as well, its always important to check the MSDS for each material you are going to weld
Shmee 10-24-2011 04:20 PM
I confirm about galvanized steel. I used to work in an elevator shop and weld that a lot with no aspiration system and had to quit before 1 year for health purpose order of my doctor, started having symptomes
after few month ,same for the guy who was working with me and the previous welder who worked there for over 6 year died.
Skytard 10-25-2011 06:55 AM
Oh my god. This must be a warning sign from the Gods. I was littlerally about to go pick up some break cleaner to clean off the oil on some tube I was welding on for my job. Thanks for posting this, it may have saved my life!
Hotshot 10-27-2011 08:24 PM
I've used brake cleaner, degreaser, and whatever was handy in the shed to clean that oil film off steel. I'll never do it again. Thanks for this post, I'm going to pass this info on to some friends.
SamPsychoWise 10-27-2011 08:32 PM
I fought with my job for a year before they would give me a resporator. Also once a year I take a Pulmonary function test. Job required for people who use a resporator.
Good looking out!
iced98lx 10-27-2011 08:35 PM
If you don't have a ventilation system (down draft or up draft tables) to weld on, or items are too big always be aware of what you're welding and what has been put on it!!
TJRHD 11-03-2011 08:25 AM
184 Attachment(s)
wow
2doorxj 12-01-2011 10:57 PM
Im guessing a chlorine free brake cleaner would be a better substitute?
RenoF250 12-31-2011 03:52 PM
I doubt it, it has pretty nasty stuff in it as well. I always though brake cleaner left no residue. I think I electronic contact cleaner leaves no residue but I would not bet on it.
bobjenkins 01-13-2012 08:00 PM
Good advice better save than sorry.
The time now is 01:26 AM.
