Quantcast Welders - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Welders
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 11-09-2008, 07:05 PM   #1
YUNGHOLDER
Welders
Thinkin about buying a welder but not sure what to buy anyone got any suggestions for a beginner?
YUNGHOLDER is offline   Reply With Quote
Old 11-09-2008, 07:09 PM   #2
Ridin' Around
Wanna Go Along?
Ridin' Around's Avatar
Hobart makes a lot of nice smaller wire welders, those with flux core will be cheaper, I prefer those with plain wire and then you will have to add a tank for the shielding material. I started with a small Hobart and have moved on to a Snap-On Welder now. Good luck!
Ridin' Around is offline   Reply With Quote
Old 11-09-2008, 07:12 PM   #3
Ratmeat
X2
Had my Hobart for over 15 years No issues!
Doing my own thing, and being an individual since 1967!
A veteran is someone who, at one point in his life, wrote a blank check made payable to The United States of America, for an amount of up to and including his or her life. That is Honor, and there are way too many people in this country who no longer understand it.
Ratmeat is offline   Reply With Quote
Old 11-09-2008, 07:33 PM   #4
schecterguy
I just ordered a hobart handler 187, from northern tool, great price, came with a free cart lol.
schecterguy is offline   Reply With Quote
Old 11-09-2008, 07:51 PM   #5
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
The Hobart 187 is a perfect machine for beginners.
"'Did you ever wonder why we had to run for shelter when the promise of a brave new world unfurled beneath a clear blue sky? "
Roger Waters
Matt Gertsch is offline   Reply With Quote
Old 11-09-2008, 10:26 PM   #6
89SAFARIXJ
1989 XJ Cherokee
how thick of steel will the hobart 187 weld?
1989 Jeep Cherokee Laredo Build
89SAFARIXJ is offline   Reply With Quote
Old 11-10-2008, 12:42 AM   #7
RockWoRM
don't fear the Jeeper
RockWoRM's Avatar
I don't own one (have a 140 110V) but IIRC, since its 220, it should do up to 1/4, 5/16.
'92 YJ, 4.0, 5sp, 8.8 w/ 4.56's locked F&R, Teralow 4-1, HD SYE, BDS 5" SUA lifted on 35 MTR's. PSE front trail cage kit, 1ton TRE flip, 1"shackles, 1"BL, 1" MM. <><
RockWoRM is offline   Reply With Quote
Old 11-10-2008, 12:49 AM   #8
schecterguy
could you elaborate on that?
I was told it was a good all around machine for doing light to medium fab work on pretty much anything jeep related. I know someone who works in a jeep garage who uses one as their main (and only, I believe) welder. Did I make a choice i'm going to regret later, lol?
Thanks
Old 11-10-2008, 12:50 AM   #9
89SAFARIXJ
1989 XJ Cherokee
1/4" is good for fabbin bumpers right?
Old 11-10-2008, 08:30 AM   #10
vitapimp
Owner of REPOST™
vitapimp's Avatar
Thanks
what he means is that it is not complicated to run it.
<>< Member #35
Red Jeep Club Member #337
What you are is God's gift to you...
What you make of yourself is your gift to God.
Make a change. Be different.
vitapimp is offline   Reply With Quote
Old 11-10-2008, 09:33 AM   #11
LaCeS OuT
1994 ZJ
I have the Hobart Handler 140. Great welder and is the biggest 110v you can get. Welds 1/4" on multiple passes.
Jeep Sold! 02/2009
Need AMSOIL? Click Here!
LaCeS OuT is offline   Reply With Quote
Old 11-10-2008, 09:54 AM   #12
jp360cj
1977 CJ7
What are you looking to weld?
77 CJ-7- AMC 360, Edelbrock cam, MC2100, Fenderwells, T150/D20, NT D30/D44, 3.73, 4" Superlift, 33x12.50 BFG KMs, Shackle Reversal, Home built 4x4 tube bumpers, KC Daylighters
Future Plans: Waggy 44 front, Scout II 44 rear, Lockers, 35s or so, winch, T18, twin stick.
73 CJ6-Future project when I get out of school
jp360cj is offline   Reply With Quote
Old 11-10-2008, 10:00 AM   #13
Fred99TJ
Lincoln 135 is what I have. Good for 3/16th COULD do 1/4" but would require multiple passes and if possible both sides
Built 92 XJ For Sale
Fred99TJ is offline   Reply With Quote
Old 11-10-2008, 10:55 AM   #14
MikeMCJ
If you are serious about welding, get yourself something that will handle the majority of what you want to do. the 110 welders are going to limit what you can do and are pretty weak on the duty cycle side. My advice would be to try and find an old Miller 35 (minimum) or better yet a 200. 200 can weld in AC and DC, it can also weld CRES, and Aluminum - if you can supply the amperage, that is. I have a 30A circuit so I was limited if I wanted to run the welder and other power tools at the same time. Miller 35 is 150A@60% duty cycle and can be bought for as little as $500. Most have a nice Tweco, not the cheap stuff they put on new 110 welders nowadays.
MikeMCJ is offline   Reply With Quote
Old 11-10-2008, 11:05 AM   #15
ChiliPalmer
Bacon Ends & Pieces
ChiliPalmer's Avatar
If you can afford it go straight to a 220 machine. The 110 machines are good if you're in an apartment, etc. but you'll quickly realize you should've gone with a 220...
If you want to help the sport of offroading visit the EnviroBeat Forum!
Blue Ribbon Coalition | Idaho State 4x4 Association | UFWDA | NAXJA | The KAT Team!
ChiliPalmer is offline   Reply With Quote
Glock Forum
