Welder questions - JeepForum.com
post #1 of 9 Old 08-22-2012, 01:32 PM Thread Starter
WorrGame13
Welder questions
Ok, so I have an old arc welder, Lincoln if I remember right, I got from my dad. What I want to know is if what I have is good for what I'm wanting to plan for my YJ? Probably the most demanding project would be a 4 link setup. I'm just kinda going crazy with ideas right now and need to get a good idea of the tools I have at the moment.
WorrGame13 is offline
post #2 of 9 Old 08-22-2012, 06:17 PM
ljrubitm
2011 JK Wrangler
More imfo on the welder. What voltage? AC or DC. What model is it?
ljrubitm is offline
post #3 of 9 Old 08-22-2012, 08:07 PM
robphillips00
2009 JK Wrangler
It'll work but you need a lot of skill to do what your thinking about doing. If you have to buy leads you may want to consider a wire welder.
robphillips00 is offline
post #4 of 9 Old 08-22-2012, 11:01 PM
AGDubyaJ
if you learn to stick weld, you can weld with pretty much any process. even if its an AC, it still worth firing up and learning on, no reason to go shell out a bunch of money if you have something that will work to learn on. i learned to weld with a lincoln AC buzzbox... that my dad gave me. they definetly have their limits, but you can still make it work. go pick up some 6011 and 6013 sticks and start laying flat beads, lots of guys will say to learn with 7018 but i find it is easier to see the arc and puddle of a 60s rod, which makes it a whole lot easier.
once you can put down a nice flat weld, try joing some pieces! dont forget to post some pictures!
98 XJ- 4.0L, NP231, AW4, chryco 8.25, 4.5" mid arm 3-link, 285/75 Herc terra tracs on moabs, V8 ZJ tie rod, fabbed bumpers...
AGDubyaJ is offline
post #5 of 9 Old 08-23-2012, 03:51 PM
zachv
PLEASE do not "learn" to weld on a 4-link project. There are some serious forces that need to have proper attachment points in a suspension.
With that said, arc welding is a great way to learn the process of welding. It is frustrating to have the electrode stick to the work piece, but once you figure out how to do it you will learn how to watch the puddle and gain deep penetration.
Have a great day!!!
Zach Vaughn.
570-385-3931--shop
zachv is offline
post #6 of 9 Old 08-24-2012, 07:22 AM Thread Starter
WorrGame13
I wasn't planning on learning as I go. I do have a very little bit of experience stick welding already but haven't done it for about 4 years and definitely need the practice before I start something like that.
post #7 of 9 Old 09-17-2012, 09:16 PM Thread Starter
WorrGame13
This is the welder I have, it's clearly not a Lincoln.
post #8 of 9 Old 09-18-2012, 03:29 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
That's a nice "vintage" stick welder. AC/DC and 250amps.. if it works well, it'll do anything you need for brackets, bumpers, axles..etc. As mentioned, make sure your up to speed on your welding prior to tackling anything critical.
BESRK is offline
post #9 of 9 Old 09-19-2012, 04:14 PM Thread Starter
WorrGame13
One of my first welds. Welding two pieces of 2" diameter tubing end to end using 7018 sticks. Very first pit a hole through the tubing
