Welder leaking gas? - JeepForum.com
post #1 of 2 Old 03-29-2011, 07:37 PM Thread Starter
carvex
1976 CJ5
Welder leaking gas?
Not being a welder myself, I'm asking this question for a friend. He has a Lincoln MIG which has worked great for years. He bought a small tank of gas (I'm not sure what it is, sorry), and hooked it up the same as usual, and it had 2000psi to start. He blew through the entire tank in less than half a roll of wire. Same thing with the next tank. The regulator also reads a lower pressure every time he looks at it. It's like it's leaking, but the main valve is always off when not welding for more than a few minutes. Is it possible to have a super slow leak on 2 tanks in a row? I don't know much about them other than the basic function. Thanks!
carvex is offline
post #2 of 2 Old 03-29-2011, 09:11 PM
wushaw
Rockin jeep
wushaw's Avatar
Take a bottle of Windex or soapy water and just check everything for leaks. I go through a bottle @ every two years and several rolls of 11lb rolls.
wushaw is offline
Welder 87jeepyj Fabrication Shop 34 03-02-2011 10:34 AM
Looking for welder bobbybare Fabrication Shop 1 04-07-2009 08:17 PM
nub welder ?'s heezy101 Fabrication Shop 4 04-07-2006 11:42 AM
100 amp arc welder enough penguinland Fabrication Shop 7 08-15-2004 01:35 PM
Welder? Briznett Fabrication Shop 3 08-10-2004 10:54 AM
