Welder heat and speed settings? - JeepForum.com
post #1 of 4 Old 07-23-2004, 04:41 AM Thread Starter
EnderUSAF
I just picked up a lincoln weld-pak 100 for 90 bucks and a trade. I'm new to welding and trying to figure out what settings to use for the heat and the speed. Is there any rhyme or reason to what settings to use for different types of metal or is it just a personall preference. If anyone's got a weld-pak 100 what settings do you usually use?
Combat Search and Rescue: If you go down, I'll come.
EnderUSAF is offline
post #2 of 4 Old 07-23-2004, 09:17 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
It should have come with a guide that tells you what settings to start off with for a particular metal thickness. If I don't have that, I usually start off with as high a heat setting as I can weld with without burning thru all the time. This way, I'm getting good penetration. I adjust the wire speed to keep a good steady flow of wire without pushbacks (too fast) or surging (too slow). I adjust as I go until I get a good bead. After awhile, you get to know about what settings you're gonna need to start with based on the metal thickness.
BESRK is offline
post #3 of 4 Old 07-23-2004, 01:16 PM
390fastback
390fastback's Avatar
Should be a chart under the door for the wire roll.
2000 Cherokee
68 Mustang Fastback (in progress)
71 Mach 1
68 Wildcat (also in progress)
68 International 1200 4x4
78 F150 4x4 400 4spd
390fastback is offline
post #4 of 4 Old 07-24-2004, 01:39 PM
fausto
You should be able to download all of the info from Lincoln www.lincolnelectric.com.
Have fun with the new toy, and the best thing you can do is get a big hammer and a vice and try and break your new welds, it will help you see what works.
fausto is offline
HU settings vs mp3 player settings Jeeptastic Audio, CB & Ham Radios, GPS, & Electrical 1 05-17-2007 08:16 PM
Settings for MRD-M300 spyderbyte Audio, CB & Ham Radios, GPS, & Electrical 18 07-29-2006 11:29 PM
JVC headunit - What are these settings for? tmtcox Audio, CB & Ham Radios, GPS, & Electrical 8 06-22-2006 11:05 AM
Amp Settings RubiconSS Audio, CB & Ham Radios, GPS, & Electrical 28 06-14-2005 08:38 AM
Stereo Settings LOCKED UP Audio, CB & Ham Radios, GPS, & Electrical 1 08-01-2002 10:38 PM
