Quantcast Welder Cart Build Up. - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Welder Cart Build Up.
Old 09-19-2008, 02:46 PM   #1
_JEEP_
I just finished building and painting my welder cart. I was looking for somthing small and compact. I have a small work space so i needed something small.
The cart fits a lincoln mig 140 and has a few hooks to wrap the ground clamp and the gun around. It has a little tray to hold some tips, soap stone pencil, replacement lens... etc
This is my first welding project. I think it turned out well
Here are some pictures:
_JEEP_ is offline   Reply With Quote
Old 09-19-2008, 07:32 PM   #2
ar4130
1997 XJ Cherokee
The finished product looks really good.
1992 YJ -2.5 Old Man Emu lift, RC 1-1/4" Boom greasable shackles, JKS Discos, 1" Daystar BL, 33x12.5x15 BFG AT KO's mounted on 15x8 Cragar soft 8's, flush mounted tailights, SJFab front bumper, TKH Fab swingout tire carrier welded to a Dirtworx rear bumper, Tuffy stereo console, RC SS Extended brake lines, Home brew plate relocation bracket, Magnaflow Cat, Dynomax Cat back, No track bars front or rear
1997 XJ - 4.5 RC coils + extra OEM spring isolator(6.5" actual front), OME medium duty springs+OME extra leaf + Teraflex 1.5 shackles (6.5" actual in rear), OME Long travel shocks, OME SS, IRO Adj TB, IRO Adj LCA'S, IRO Adj Uppers, RC Control arm drop brackets, JKS Quicker Discos, SYE / XJ shaft, 33x12.5x15 BFG AT KO's on 15x8 Cragar soft 8's, RC SS extended Brake lines, Hella 500's
1996 ZJ - RE 2 inch BB w/shocks (rides like crap), OME SS, 31x10.5x15 General Grabber AT2's - SOLD
ar4130 is offline   Reply With Quote
Old 09-19-2008, 08:47 PM   #3
dickensheets
Now just add a bracket for the bottle and ur done
I like it.
99 WJ V8, 245/75/16 MT/R and Rusty's 2.5" coils and shocks, IRO trac bar, homespun end links, block heater!! 220V MIG w/75-25 and OXY/Acetalene rig if you need it! Just let me know
dickensheets is offline   Reply With Quote
Old 09-19-2008, 10:34 PM   #4
_JEEP_
I like it.
yup when i get my argon bottle i will weld up a secure frame then ill weld it onto the back of the cart.
Glock Forum
