Weld Sliders to tub? - JeepForum.com
post #1 of 6 Old 03-04-2013, 05:39 PM Thread Starter
drerict
1983 CJ7
I have an 83 cj 7 and it is starting to get a little rest spots on the rockers. There is one on each side about the size of a nickle.
So can I weld sliders to the tub rather than bolt them. My intent is to grind and sand, and repair the rust first. Then weld the sliders, then paint the cj.
Any thoughts or recommendations?
Thanks,
Eric
Firefighters Jeep Club
drerict is offline
post #2 of 6 Old 03-04-2013, 06:21 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I think I'd patch the holes, then bolt the sliders in place.
Trying to weld the thin sheetmetal to the sliders would be a challenge.. and it would be really tough to do it cleanly.
BESRK is offline
post #3 of 6 Old 03-04-2013, 07:42 PM Thread Starter
drerict
1983 CJ7
I didn't think of the sheet metal thickness.
I guess it will be a bolt on.
I was concerned about getting moisture between the two and having more rust, so hence welding them on.
drerict is offline
post #4 of 6 Old 03-05-2013, 12:35 PM
tjcj
Fix the rust, then bolt up the sliders. Then run a bead of silicone where the tub meets the slider.
Sent from my XT881 freezeray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #5 of 6 Old 03-05-2013, 12:53 PM
biffgnar
biffgnar's Avatar
Think carefully before pulling on silicone. Chances of getting it 100% sealed are low and you can just end up trapping anything that does get back there. Additionally, if you ever take the sliders off, you've made your job a lot more difficult and may end up deforming the tub to get them off.
Romney in 2020!
biffgnar is offline
post #6 of 6 Old 03-12-2013, 07:09 AM
thantos858
1974 CJ5
http://www.genright.com/ProductInfo....ductid=RCG1000 use that kind of product over silicone and you wont have a problem.
thantos858 is offline
