Quantcast Waggy D44 axle truss? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Waggy D44 axle truss?
Old 11-13-2006, 04:19 PM   #1
E_ROCK
Has anyone fabbed a front axle truss on a driver side drop wagoneer D44? I would like to see some pictures. I am failing to come up with a good plan on the driver side because their isn't a lot of room.
Garage Monkey, Wheeling Junkie
www.rockfrogs.org
E_ROCK is offline   Reply With Quote
Old 11-13-2006, 05:38 PM   #2
Bryson
What about the blue torch truss?
99 chilipepper red XJ: Race car tow rig. Turbo project in the works.
Head of Core production - www.CortekSystems.com
Owner of Boostwerks.com
Website in development.
Bryson is offline   Reply With Quote
Old 11-13-2006, 06:11 PM   #3
E_ROCK
The blue torch is designed with with wider D44 in mind. There is no room to weld the driver side portion of the truss to the tubes because my spring perch is on the diff housing.
www.rockfrogs.org
Old 11-13-2006, 07:09 PM   #4
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I'd cut off the shock mount, bend a piece of 1.75"x .188" wall DOM (that's what I used) into a "U", weld it down there and on the other side of the pumpkin (on the opposite side tube), and then cut/weld a 3/16" plate to "fill in" the area between the tube truss and the axle housing. Then, I'd do a few gussets off the assembly to keep it from bending fore/aft. Here's a few pics of my truss. It's on a D60 but the concept is the same..
and if I'm not mistaken, that BTF truss will fit with a perch still in place. If you're going to a link suspension just cut the perch out of the way. The BTF truss slides right up against the pumkin casting and welds to the tube. I installed one on my buddy's D60.. nice setup and very strong.
'80 CJ5 w/AMC360, T176, D44 w/Detroit 3.73s, RE 4" YJ lift and 35s..
Ground Pounder Fab
Lower 2
Guardrail
Down Schoolbus
Slickrock Tellico
Save
Crozet
More Crozet
BESRK is offline   Reply With Quote
Old 11-14-2006, 07:49 AM   #5
E_ROCK
I was more thinking something like this but for my axle. I just need a creative idea for the driver side area. This is the TnT dana 30 version.
www.rockfrogs.org
Glock Forum
