Upper shock mount placement for shocks - JeepForum.com
post #1 of 6 Old 11-21-2008, 11:13 PM Thread Starter
desertcrawler86
Hey guys so I'm thinking about going with coilover shocks. I was thinking about using the fox 2.0 shocks and was wondering how you determine where to place the upper shock mounts? Do you let out all the gas out of the shock and compress the shock all the way then jack upn the axel and build the mounts from there or is there another way to do it? I'm planning on extending my tj wheel base from 94" to around 100 to 104 and was thinking about installing the 2.0's?
desertcrawler86 is offline
post #2 of 6 Old 11-22-2008, 01:45 AM
izanuff
izanuff's Avatar
what size tires and how much lift are you trying to achieve?
Originally Posted by Luckyduck View Post
I just went and grabbed 2 rubi axles locked and everything for $100 each then $1000 for 2 entirely new stronger housing and bingo I got 2 locked 44's that are as strong as 1 tons for $1200
1 TONS!
izanuff is offline
post #3 of 6 Old 11-22-2008, 02:28 AM
ChiliPalmer
This is Ames Mister...
ChiliPalmer's Avatar
It's my understanding that you measure your travel first and then order the shocks to fit. From there you can adjust the shock travel to fine tune it.
Check out this aritcle for more info...
If you want to help the sport of offroading visit the
Forum!
Oh man Chili. I feel like a recovering addict that just had a bag of blow, a bottle of Jameson, and a sack dropped in his lap. You screwed me man!
ChiliPalmer is offline
post #4 of 6 Old 11-22-2008, 04:41 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You're trying to zero in on the correct "spring rate" so your rig set at the ride height you want with the proper amount of shaft stickout at static ride height.
If you don't know how much "sprung weight" you've got up front, you can install the shocks with one spring on them and see how much the rig compresses that single spring (on each side of the vehicle). That'll give you the approx sprung weight.
For shaft stickout, I try to get about 4" or so for a street driven rig. That should keep you from bottoming out too often.
BESRK is offline
post #5 of 6 Old 11-23-2008, 04:50 PM Thread Starter
desertcrawler86
I'm not sure how much I should have. I would like to run 37" tires with a 8.8 and a dana 44 in the front. I live in So Cal and we have eveything from the hammers which is extremly rocky to sand to mud hills. So I'm not sure what is the correct setup. I was thinking about buying the rancho 5.5 long arm lift kit and buying 7.5 inch spings for it but I don't want to pay 3 grand on a lift kit when I could buy a poly performance lift kit and extend the wheelbase to 100+ for less money.
post #6 of 6 Old 11-23-2008, 04:52 PM Thread Starter
desertcrawler86
The link sent me to an error page.
Rear Upper YJ Shock Mounts smithhobbies Fabrication Shop 5 10-05-2009 08:34 PM
TJ shock placement with the rear shocks? desertcrawler86 Fabrication Shop 4 07-08-2008 01:14 PM
homemade upper shock mounts YJames90 Fabrication Shop 24 09-20-2007 06:04 PM
placement and mount of cb and antenna rescue96zj Audio, CB & Ham Radios, GPS, & Electrical 5 11-13-2005 07:00 AM
Shock Placement SAJeep Tires & Wheels 2 05-29-2003 08:49 PM
