Ugly Welds...help? - JeepForum.com
post #1 of 19 Old 05-25-2013, 12:56 PM Thread Starter
StrokedWJ
StrokedWJ's Avatar
Ugly Welds...help?
Its been a year or so since I needed to use my welder and in that time I got sold my Lincoln 180 and am now using a Hobart 187. I can't seem to get the hang of the Hobart. I've got ugly tacks with craters. I've checked polarity and its correct according to the sticker inside the door. 1/8" steel, cleaned, Pwr. lvl 5, wire speed 50, ~20cfm 25/75 gas.
2000 WJ 4.5L - Stroked, Locked, & Long-Armed
Looking for 6" WJ springs!
StrokedWJ is offline
post #2 of 19 Old 05-25-2013, 02:28 PM
tjcj
Kinda looks like you forgot to turn on the gas or ran out of gas ? Maybe a breeze blowing away your shielding gas.
Sent from my XT881 freezeray gun using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #3 of 19 Old 05-25-2013, 02:43 PM
rebelbowtie
Yea youre losing your shielding, you need to turn up the flow or take the piece inside. You may also have some rusty wire causing some of the perosity.
rebelbowtie is offline
post #4 of 19 Old 05-25-2013, 03:50 PM
95YamJam
Like said above looks like poor sheilding or wind. I have a weldmark 187. Try 3/40 with about 15-20cfm.
My build: http://www.jeepforum.com/forum/f22/95-yam-project-1527472/?highlight=
95YamJam is offline
post #5 of 19 Old 05-26-2013, 04:05 PM
wushaw
Rockin jeep
wushaw's Avatar
See if you even getting gas to the nozzle first, undo the roller off the wire feed so wire don't feed out and hit the trigger and listen for gas flow at the nozzle.
wushaw is offline
post #6 of 19 Old 05-26-2013, 04:17 PM Thread Starter
StrokedWJ
StrokedWJ's Avatar
Thanks for the replys. I'll look into the gas issue. I could see the regulator needle moving when I'd push the trigger. It was definitely a little windy too.
post #7 of 19 Old 05-26-2013, 07:35 PM
danielbuck
1946 CJ2
What I do before I start doing my first weld of the day, is I undo the rollers on the wire, pull the trigger for a few seconds to clear the tube of air so that it's all full of the mix gas. Then I pop the roller back on and start welding. Before I started doing that, every now and then my first weld would look ugly and pitted like that. But even so, after a few seconds of welding the gas should fill the tube. Definitely check to make sure gas is coming out. And yea, a little bit of wind will carry it away :-\ I try to do all of my welding just inside my garage, 4 feet or so. That usually does the trick. If I have to weld on the jeep outside, I just wait until I don't feel any wind, then go.
danielbuck is online now
post #8 of 19 Old 05-27-2013, 01:23 AM
wushaw
Rockin jeep
wushaw's Avatar
The needle on the regulator doesn't tell you if your getting gas at the nozzle. If the gun lead is not plugged into the machine all the way the gas will just diffuse into the machine, if the O rings are shot then it will do the same thing.
It takes 2 seconds to open the machine & lift the roller tensioner off to keep wire from feeding into your ear while you listen for gas.
wushaw is offline
post #9 of 19 Old 05-27-2013, 02:28 AM
Syncityj
It looks like the heat maybe too hot, and when you finish your puddle, or your wide weave you long arc. From what I have been told, you want to maintain about a 1/8" gap from weld to tip. When you're doing puddle welds I will circle the puddle once and pull straight up and out. You don't want to move slow at the end or you will long arc and burn a hole in your piece.
Syncityj is offline
post #10 of 19 Old 05-27-2013, 10:41 AM Thread Starter
StrokedWJ
StrokedWJ's Avatar
Just checked and I do have gas at the nozzle. Thanks for the suggestion on how to check.
post #11 of 19 Old 05-27-2013, 10:17 PM
bigbossd1030
It's porosity. Don't weld with gas in wind. You can fart and it will blow it away. I you are welding outside crank the gas. When I weld inside I and at 34-36cfm. A little more gas beats a weak weld with porosity in it. An having to grind out the bad weld.
Sent from my iPhone, probably because I am bored at work.
/l ,[____],
l----L-[]lllllll[]-
()_)-()_)--o)_)
OFFICIAL JEEPER
Any Jeepers in Edmonton, AB
I am on channel 33.
I live, I ride, I am JEEP.
bigbossd1030 is offline
post #12 of 19 Old 05-28-2013, 06:29 AM
Ironworker709
Ironworker709's Avatar
I run at most 15-20 inside,and maybe 25 outside ,it doesnt matter how high it's set outside,if the wind blows it's goin to blow away your sheilding and cause porosity.
Check the O-rings and possible cuts or holes and flat spots or kinks on your whip hose.
Don't DREAM your life, LIVE your dreams
Never forget 9/11
"Welding is like a woman,Get 'er HOT and Penetrate"
Gotta LOVE a person who knows everything about NOTHING
The only Thing necessary for the Evil to win is a good man to do nothing....
"How far you go in life depends on your being tender with the young,compassionate with the aged,sympathetic with the striving,and tolerant with the weak and strong--because someday YOU will have been all of these"....George Washington Carver
Want to know what an Ironworker is and the job scope of a Journeyman?..click here...
Ironworker709 is offline
post #13 of 19 Old 05-28-2013, 10:22 AM
95YamJam
X2 15 to 20 is more than enough with 75/25.
Honestly knowing that welder it was too hot for power plus possible wind issues.
95YamJam is offline
post #14 of 19 Old 05-31-2013, 02:22 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
I have had an exhaust fan blow away my shielding gas. Thats why I stick weld, no shop or garage and a gravel driveway is all I have.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #15 of 19 Old 06-03-2013, 02:59 AM
wickedwj99
1 no shielding gas 2 don't run above 15-20 max 25. That's what I used while In Iraq while In sand storms. 3 use a shielding blanket if there is to much wind.
I have also heard those stick on chrome vents from Walmart add like 75+ HP..
wickedwj99 is offline
