tubing bender - JeepForum.com
post #1 of 3 Old 08-20-2005, 04:19 PM Thread Starter
ugrider21
tubing bender
hey all you fab guys, i really want to get into making my own stuff, and i want to start off easy with a simple front hoop resembling the Warn one. the only problem is.......tools and supplies. i have access to welders, but not benders. i was considering getting one. what would you guys suggest? are the manual ones easy to use? should i just save up and get an electric one? tell me all you know!!!
also, what kind of tubing should i use? also, tell me all you guys know about that.
i'll be sure to post up about my hoop when i start getting it done.
thanks alot!
'97 Sport green, 4.0 5spd, Bestop supertop, RE 3.5", 33x10.5 BFG a/ts on 15x8 Cragar 397's, Warn rockcrawler front bumper, KC 100W on windshield, Hella 500 fogs on bumper, K&N intake, Flowmaster 40, Herc'd interior, B&M shortthrow, PORC SYE, Collis custom CV shaft, Nth Degree rear UCA's, Gopher-it bell-up, Novak t-case shifter, MORE 1" MML/BL.
ugrider21 is offline
post #2 of 3 Old 08-21-2005, 10:40 AM
Down&Dirty
Down&Dirty's Avatar
Look at a JD model 2 or 3. Check over on pirate4x4 and you can find them used with a die. Won't save much money though. A good manual bender with a single size die will run you almost $700. Some will suggest the simple harbor frieght or northern tools hydralic bender, but these are a waste of money. They will kink the tube or flatten it out when bending. Tubing should be DOM and if that is too much money you can go to HREW.
53 willys wagon with less of rust and no more bugs. Now sporting a 1988 wagoneer frame, amc 360, dana 44's.
'80 CJ-5, full width, 3 link front, 1/4 elliptical rear, 38's, and propane.
Down&Dirty is offline
post #3 of 3 Old 08-21-2005, 12:21 PM Thread Starter
ugrider21
thanks for the info! i'll look into that
just got tubing bender!!!!! 99dime Fabrication Shop 7 02-03-2008 05:58 PM
Tubing bender Indy Fabrication Shop 1 12-05-2006 09:16 PM
ing tubing bender gumcrew2 Fabrication Shop 19 03-08-2006 10:31 AM
Tubing Bender CJ51973 Fabrication Shop 5 05-22-2005 06:07 PM
Which tubing bender? BESRK Fabrication Shop 2 08-19-2004 08:08 PM
