tube fenders made from ur stock fenders - JeepForum.com
post #1 of 13 Old 12-11-2010, 09:40 PM Thread Starter
jeepasaurusflex
i wanna see some stock fenders turned into tube fenders.anyone who has done this post up some pics please... id like to know specks and what material was used..thanx..
jeepasaurusflex is offline
post #2 of 13 Old 12-13-2010, 09:38 PM
'92 vegas YJ
ive been searching for the same thing for 2 days. im gonna be watching this one. have an extra set of fenders that i wanna make tubes out of while still retaining the inners and probably the sheet metal on top....
'92 vegas YJ is online now
post #3 of 13 Old 12-14-2010, 08:17 AM
autoboy454
when I build mine (tubes with 3" flare) I was planning on reusing the inner fender and sheetmetal, would be really nice to get some specific measurements and specs.
Love to wheel? Live in/around Massachusetts? Check us out!
autoboy454 is offline
post #4 of 13 Old 12-14-2010, 09:38 AM
Jeep_tj_97
Jeep_tj_97 is offline
post #5 of 13 Old 12-18-2010, 09:44 AM
Chris
Guy with jeep
Chris's Avatar
Here is my little write up. It was pretty easy and I like them.
http://www.jeepforum.com/forum/f12/m...nders-1068485/
Chris is offline
post #6 of 13 Old 01-31-2011, 08:17 PM
'92 vegas YJ
well i decided to try it out. i ended up cutting everything off but the inner fender and top. i then had some tube bent and made my side pieces and went to town.
im down with one and will be working more on the other one next weekend. just have to do mock up, tacking then fully weld that one.
will post a build thread most like when i am done....
post #7 of 13 Old 02-01-2011, 02:48 PM
kelti819
Here is a pic of mine. i used some conduit from home depot and a small pipe bender then trimmed the door edge with angle iron and did all the body work.
kelti819 is offline
post #8 of 13 Old 02-02-2011, 06:49 AM
McFatter
Went ahead and just now made this thread just for all of you lookin lol
http://www.jeepforum.com/forum/f12/m.../#post10901134
McFatter is offline
post #9 of 13 Old 02-09-2011, 09:25 PM
'92 vegas YJ
ok here it is.
took me a little while but i got it done.
hope this helps you out jeep
http://www.jeepforum.com/forum/f12/d.../#post10949922
post #10 of 13 Old 03-13-2011, 08:55 PM
ccbruin
You used conduit? how has it held up? did you weld it to the sheet metal?
ccbruin is offline
post #11 of 13 Old 03-14-2011, 06:25 AM
kelti819
its held up fine, the only issue i had was that i didnt weld where it meets the fender on the firewall side that well and it broke free easy fix though
kelti819 is offline
post #12 of 13 Old 03-14-2011, 06:38 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Everyone always makes these with the straight line sharp cut upper rear corner of the opening. If I ever do this I'd make the top outer tube nicely curve bend downward and go to the rocker guard. A square cut hole to accommodate a round tire seems like it was a quick field fix, a rushed design.
The bought ones that include a flare section are usually more what I'm talking about.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is online now
post #13 of 13 Old 03-14-2011, 07:04 AM
kelti819
i agree but seeing as how i did the angle iron down the side to prevent tire cutting i did it this way. im happy with how it looks and stuffs and i have not had any issues to date other than me not doing a good enough job on the welding in one spot.
kelti819 is offline
home made tube fenders 90YJax15 Fabrication Shop 24 04-23-2010 06:22 PM
have any of you guys built your own inner fenders for tube fenders??? Goobersbro Fabrication Shop 11 10-29-2009 11:52 PM
Tube Fenders Black Hills TJ Fabrication Shop 2 11-26-2007 03:05 PM
Custom made tj fenders eclipse27 Fabrication Shop 6 05-22-2007 03:42 PM
tube fenders gigihurt Fabrication Shop 1 07-05-2006 07:34 AM
