Quantcast Tube Fenders - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Tube Fenders
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 01-04-2010, 04:44 PM   #1
sebastian22
Go Kings Go!
sebastian22's Avatar
Tube Fenders
Just thought I would post this here to share our experience in making a couple sets of tube fenders over the past two weekends.
First we went to the steel shop to buy some steel...
Some of this stuff was of other projects, but for the tube fenders we used 1 1/2" diameter x .120 wall tube, and we got some 12ga scrap sheets in various sizes (not sown in picture). We also used a 3/16" thick x 1 1/2" wide flat bar for the mounting material.
Started off by removing my front flares and cutting the factory fender (a little bit painful considering it was in perfect shape).
Next we measured, cut, and bent the horizontal tube at 90 degrees. We left some extra material at both ends to be sized later.
Then we measured, cut and drilled for the tub mount flat bar.
The fun part..."shaping" the grill mount. Only fun for the guy who gets to hit it with the hammer.
Then we measure, cut, and bent the vertical tubes...
The next step was to mark (eyeball) the angle of the cut where the tube mounts to the grille. We did this by holding a straight edge to the body and following it with the tube. No picture since this involved all of us.
Next we tacked the horizontal tube, notched the vertical tube, and tacked it on. Also made a duct tape template of the top plate by laying duct tape along the top of the tube and cutting it with my poor pocket knife along the center of the tube. (the template is seen here on the tire after being transferred to the plate).
We cut the top plate with the plasma cutter and grinded it smooth with flap disks. Then test fit it on both sides, tacked it on, and removed the tube fender for welding.
Then we templated the vertical plates, cut those out, and welded them on. The plate were welded to the tubing and flat bar with a 1-2" long weld every 4-5" or so.
Next I designed and cut out a little gusset and Jimmy welded it on.
That was it for my set of tube fenders. I took them home, grinded (ground) the material that overlapped smooth, cleaned everything off with simple green, primered and painted them. I used 1 can of nice black primer we got at the metal place, then 1 can of Rustoleum gloss black.
Let them dry overnight and mounted them the next day.
Drilled the holes for the hood latches, and sprayed a quick layer of paint on the exposed metal from the holes.
Total cost was about $90 including steel and paint.
Also cost me a pair of pants when i was notching one of the tubes and the cutting wheel got caught and came back and bit me in the upper upper thigh. Luckily it only caught my pants and not anything else.
Well, thats about it. Hope that helps if someone is looking to build their own.
sebastian22 is offline   Reply With Quote
Old 01-04-2010, 05:14 PM   #2
WebWheeler327
Nice job. Your rig looks sick with the flares.
[SIZE="5"]Arte et Marte[/SIZE]
WebWheeler327 is offline   Reply With Quote
Old 01-04-2010, 06:00 PM   #3
wmeyer116
looks awesome man. good work
Originally Posted by never monday View Post
Marcus,
Leave your inbred childish comments somewhere else. They are not welcome on JF
wmeyer116 is offline   Reply With Quote
Old 01-05-2010, 11:00 PM   #4
-cAcHe-
looks great...now my GF wants some for her JK...thanks..
haha
www.desert-hooligans.webs.com
Originally Posted by CarolinaWK View Post
I like happy endings :2thumbsup:
RIP Troy Edwards (bigbluezj94)
-cAcHe- is offline   Reply With Quote
Old 01-06-2010, 01:02 AM   #5
Joe Dillard
Free clues & suggestions
Joe Dillard's Avatar
Looks real nice!
Joe Dillard is online now   Reply With Quote
Old 01-06-2010, 06:05 AM   #6
rustywrangler
Got my eye on you.....
rustywrangler's Avatar
I really like how you incorperated the factory fenders to keep the wheel wells covered in. I know they were in good shape but damn those look good.
http://i131.photobucket.com/albums/p...k_banner-1.gif
Congenital Heart Disease is a reality for me, BOTH of my children have it. Please read up and become aware for future generations
Lydia Ann-Acquired 08/05/05 Open Heart surgery 08/10/05
Jacob Patrick-Acquired 01/17/08 Open Heart surgery 02/15/08
rustywrangler is offline   Reply With Quote
Old 10-28-2010, 04:18 PM   #7
Crush03
wow man nice fab
jeep
Crush03 is offline   Reply With Quote
Old 10-28-2010, 04:51 PM   #8
sebastian22
Go Kings Go!
Thanks! it was interesting doing 3 sets on 2 different type of Jeeps. but it was a lot of fun...we split up into teams of 2 and actually worked pretty efficiently.
Old 10-28-2010, 05:05 PM   #9
Leans93
She's my density...
Leans93's Avatar
Very nice work! Very professional looking!
M.F. Leans
93' YJ 4.0L AX-15, 4" Pro Comp lift, 3/4" shackles, 1" BL, 33x12.5x15 BGF MT's, and some other stuff
Leans93 is offline   Reply With Quote
Old 11-03-2010, 01:49 PM   #10
heavypedal
Those fenders look awesome! I want to show my buddy these for his YJ...
2006 LJ Rubicon, R.E. Long Arm lift, 35 inch BFG's, ORF sliders, LED's under frame, on board Viair, Hard-rock roll-cage and rear bumper/tire swing w/ gas cans, Cobra CB, Hanson front bumper, Warn 9.5ti winch, Rock Krusher Diff guards, Dana 44's front & rear w/E lockers, Optima battery, Metal Cloak fenders, LED blinkers, B&M trans cooler, Kilby steering skid, Gen-Right hood vents, Oh and... I wave!
heavypedal is offline   Reply With Quote
Old 11-17-2010, 07:25 PM   #11
RuffShod
Very nice fab work!
RuffShod is offline   Reply With Quote
Glock Forum
