Tube bender guy between Northern Jersey to Catskills? - JeepForum.com
post #1 of 2 Old 07-11-2017, 02:44 PM Thread Starter
86cj7pete622
Guys,
Anyone have a tube bender from anywhere between North Jersey/NYC to the Catskills (areas I travel often), and charge a small fee for two simple bends? Need the same degree bend made in two different DOM 1.75" .120 5' pieces to make some windshield hoops. I supply the DOM, you supply two bends. I can do 1.5" sizing if that's the only die size you have (1.5" might be even better being I want the tightest bend possible).
thx.
86cj7pete622 is offline
post #2 of 2 Old 07-11-2017, 09:13 PM
04WJny
1987 YJ Wrangler
Sent you a PM, I have a 1.5" OD x 4.5" CLR Die,1.75" OD x 5.5" CLR Die, & 2.00" OD x 6.5" CLR Die
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
