Tub mounted tire carrier - JeepForum.com
post #1 of 3 Old 07-07-2013, 09:04 PM Thread Starter
Ruff88
Removed the rear seat from the jeep and have just been strapping down my 35" spare. I want to raise it up so I have more space to store tools etc.
My plan is to use 1/8" angle iron mounted to the bed rails using the holes from the top mounting and then spanning the width of the tub with 2x2x1/8" square tubing with a riser coming out with a plate and studs to mount the tire too. I'd probably cover it with some type of plywood etc. to seal it up.
Will that be sturdy enough to carry the weight of the tire while wheeling?
Thanks
Ruff88 is offline
post #2 of 3 Old 07-07-2013, 09:09 PM
rambo3489
Yea you should be good. I mounted mine to the roll bar with 1.5x1.5x 1/8" tubing and its solid. Are you talking about one crossmember? If so it might be a little on the light side.
89 YJ.. My first jeep and I won't let it go. ▀||||▀
Current Project: None... I disgust myself.
<a href="
THE YJ MY WAY</a>
rambo3489 is offline
post #3 of 3 Old 07-09-2013, 08:06 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Thanks
Here is what I did;
http://www.jeepforum.com/forum/f12/i...rrier-1029972/
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is offline
