Tub mount hinges - JeepForum.com
post #1 of 14 Old 07-11-2011, 01:52 PM Thread Starter
Pooples
Tub mount hinges
Alright, I've searched the forum and can't find a thing. I need some help here! I want to build a tub mount swing away tire carrier but have no idea where to find hinges for such a project. I thought about hinges off of a pathfinder carrier, but I doubt they will be strong enough. Anyone have any ideas where i should look??? I have googled this and found nothing. TIA
Pooples is offline
post #2 of 14 Old 07-11-2011, 02:03 PM
corvetteguy
jeeptubes.com
corvetteguy is offline
post #3 of 14 Old 07-11-2011, 03:33 PM
92 Green YJ
92 Green YJ's Avatar
My only word of advice is to reenforce the tub behind where you mount the hinge somehow. Maybe with a large plate of 3/16" to spread the load out. Otherwise you risk seriously mangling the tub
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #4 of 14 Old 07-12-2011, 06:03 AM Thread Starter
Pooples
yeah, i plan on making a bracket that goes from the rollbar mount to the tub to reinforce it really well. Jeeptubes.com is pretty sweet, but I don't think they have what I'm looking for. I'll have to keep them in mind for other projects though!
Pooples is offline
post #5 of 14 Old 07-12-2011, 09:10 AM
corvetteguy
post #6 of 14 Old 07-12-2011, 03:08 PM
rlockwood
Originally Posted by corvetteguy View Post
I'm just as confused as the OP, there's nothing on those pages even close to resembling what the guy is looking for..?
Are you looking to add an additional set of hinges to the existing tail gate hinges? The few builds ive seen completed used the swag off road drop down tailgate conversion, which opens up the original hinges for a tire carrier. I've often considered building a set of "dual purpose" hinges, where a tire carrier is hinged outboard of the tailgate. However, since they would follow different arcs the tailgate couldn't be opened without first opening the tire carrier, which seems like it would be an annoyance. There are a few ways to engineer around it, (such as using a tie rod to push the tire carrier ahead of the tail gate) but I haven't felt like putting in the work quite yet.
rlockwood is offline
post #7 of 14 Old 07-12-2011, 03:46 PM
Mopar1994
On WAC jeepers tj-6 build there is a carrier just like a tub mounted one but it is welded to PSC corner guards and not to the tub. there are pictures on page 11, 12 and 22
http://www.jeepforum.com/forum/f22/t...3/index11.html
Mopar1994 is offline
post #8 of 14 Old 07-12-2011, 04:15 PM
corvetteguy
what I was seeing, have used, were those weld on tabs. We have mounted a bar aross the bumper mount area, weld tabs to it and use that as the swing down hinge. I too much rattle you can insert a bushing as needed.
post #9 of 14 Old 07-12-2011, 04:19 PM
corvetteguy
Im sorry...I read it as "Swing Down".....i reread it and see my error...
Sorry
post #10 of 14 Old 07-13-2011, 06:02 AM Thread Starter
Pooples
I plan on fabing up a hinge bracket that bolts under the original tailgate hinge brackets very much like the OR-FAB tub mount carrier. So I have my design, and most all of my parts now except for the hinges... I still dont know what to do about those.
Pooples is offline
post #11 of 14 Old 07-13-2011, 09:06 AM
P_RIDDY
You could use Heim joints and make a bracket out of some 2 or 3 inch channel and just use a bolt or pin down thru the heim joint?!
P_RIDDY is offline
post #12 of 14 Old 07-13-2011, 09:17 AM Thread Starter
Pooples
Thats exactly what I'm looking for! I didn't know what they were called. Thanks!
Pooples is offline
post #13 of 14 Old 07-13-2011, 09:27 AM
XtrailratedJ
I would base it off the Bestop Tub mount carrier...It is made so the tailgate and tire carrier open together, yet allowing them to swing in different arcs...
I wouldn't use a heim in this application. A greasble rubber bushing like a fixed control arm would be best...
example:
96 XJ 4.0L/AX15/NP231/AUSSIE'D D30/C8.25/4.5" RE LIFT/33'S/BUMPERS, SLIDERS, ETC...
"I pitty the fool who lists D30's and 31's, then tries to talk **** on PBB":
Originally Posted by Durt_Diver:
Those pics might be a little too flexy for this thread. You don't happen to have any pics of your friends xj on a curb by chance?
XtrailratedJ is offline
post #14 of 14 Old 07-14-2011, 10:22 AM Thread Starter
Pooples
example:
That pretty sweet, but I think its a little out of my price range to build. I'm leaning more towards the OR-FAB jerry can carrier design. I go bouldering several times a week, and it would be nice to slide my bouldering pad inbetween the tub and carrier instead of taking up the whole rear seat. I got my tubing bent up today, now I just have to figure out which heim joints to go with. Thanks for all the suggestions so far!
Pooples is offline
fabed kc mount hinges anyone do it extremecj7 Fabrication Shop 9 02-25-2009 11:21 PM
Hinges bend? GPEWETT General Jeep & Off-Road Equipment 2 07-19-2008 03:43 PM
Spare Mount/Super Hinges Bigbob Fabrication Shop 5 04-20-2007 07:49 AM
hatch hinges bigsky89 Street Jeep Forum 5 10-04-2006 12:33 PM
Painting Hinges blue1989yj General Jeep & Off-Road Equipment 5 05-23-2006 12:11 PM
