trying to remove doors on my 93 xj - JeepForum.com
post #1 of 3 Old 10-25-2012, 07:12 AM Thread Starter
ayycharlay92
im trying to take my doors off and was wondering if theres anyway i can do it without having to cut into the actual metal ? the wires im not worried about i can make a plug for that. but i saw like a pin or something that held the hinges together didnt know if i could beat that out then put something new in it or what. or even if they sell Cherokee door quick disconnects.
ayycharlay92 is offline
post #2 of 3 Old 10-30-2012, 10:10 PM
ltrail
1984 XJ Cherokee
The door pins can be hammered out. One goes down and the other had to be hammered upwards if I remember correctly. Replace with some bolts or harbor freight quick pins.
84 xj 350tbi, sm465, 203/205, 60/70. links and other junk.
what size sawzall blades does it take to fit 40's?
ltrail is offline
post #3 of 3 Old 11-02-2012, 03:23 PM
Motorcharge
Drivers side hammered down, passengers up. If you have an air compressor I'd highly suggest you invest in an air hammer. 1/4" bit will drill the holes on the hinges out just enough to fit in quick pins.
Much easier to cut the hinges, even with a quality air hammer you can just chisel through them. You can also unbolt them but you'll need shallow torx bits and a lot of patience.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
cherokee , door hinge
