Trimming rear fender - JeepForum.com
post #1 of 5 Old 01-27-2011, 12:56 PM Thread Starter
Trailabite
Ok, it's a little more than that: I have an 05 TJ with TNT tube fenders on the back. At full flex my tires are pushing into the the front section of the fender well so I want to trim this section. The TNT fenders are 3/16" thick steel and I don't want to take them off. I'm thinking on using a 4" grinder with a cutting wheel. Is there a better idea?
Trailabite is offline
post #2 of 5 Old 01-27-2011, 01:52 PM
4bangerYJ
Sawzall. I'd use the grinder with cut off wheel if it will get in there. Wear a face shield!
4bangerYJ is offline
post #3 of 5 Old 01-27-2011, 02:40 PM Thread Starter
Trailabite
The sawzall will definitely cut through it but I need to preserve the actual fender underneath the TNT steel. I would like to try and not cut through the pinch welds and mess all of that up.
post #4 of 5 Old 01-27-2011, 03:01 PM
dcope17
Pushing into the only the front of the TNT fender or the factory fender also?
If you just want to trim the TNT fender... don't be lazy, take it off and cut it...
If you're hitting the factory fender... some adj. CAs and move the axle back.
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #5 of 5 Old 01-29-2011, 01:53 PM Thread Starter
Trailabite
I would have to trim the back side also if I moved the axle back, the tires just barely touch the fender now. I may just take the TNT fenders off and trim it up the right way. There just so dang heavy...........................
fender trimming for 35's GilNewJeeper Tires & Wheels 13 12-10-2010 05:28 PM
CJ7/YJ inner fender trimming CoryA Fabrication Shop 0 02-02-2010 02:20 PM
Trimming rear wheelwells BobA General Jeep & Off-Road Equipment 0 02-08-2008 06:40 PM
fender trimming pics? jeepamongzukis Cheap Tricks & Fixes 12 05-23-2007 10:34 AM
fender trimming rocknerd Fabrication Shop 2 04-26-2004 08:56 PM
