Transmission Conversion - JeepForum.com
post #1 of 4 Old 11-04-2013, 10:49 PM Thread Starter
Adventuree9
I'm a newbie, but am optimistic that I can get some great advice and where to turn. 1977 jeep j200 pickup with automatic transmission and quadratrac. I would like to know if it can be reasonably converted to a T 18.... I don't know how feasible this is, or an estimated cost for someone who has a history in making this type conversion.....I am in SC and would welcome any advice, proper contacts and other options....thanks Rick
Adventuree9 is offline
post #2 of 4 Old 11-06-2013, 06:19 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Hi Rick.. welcome to the forum!
I don't know a lot about the J10/20 but I'm assuming yours came with a 360? There may have been some J10/20s that came with factory T18/D20s. If not, there are some T18/D20 CJs out there (kind of hard to find nowadays though). If you could pick one of those combos up, it should be pretty simple to swap out the D20 for a D18. Might also just pick up a Ford T18 and use a CJ bellhousing (been a while since I researched but I think a T150 and T176 share the Ford's butterly bolt pattern).
Best bet for better info on this swap is to hit our Fullsize Jeep Forum and our CJ Forum. I'm sure a few of the guys have done the very swap you mentioned.
Another good source of info is Advance Adapters and Novak Adapters. Both have extensive swap info..
BESRK is offline
post #3 of 4 Old 11-07-2013, 09:44 AM
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Or post up in the Engine/Drivetrain Forum.
This is more of the fabrication forum...
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline
post #4 of 4 Old 11-09-2013, 09:13 AM Thread Starter
Adventuree9
Conversion on j10/20
Thanks for your info, insight and expertise....will check into the possibities you've mentioned.....
