Trailer build question - JeepForum.com
post #1 of 5 Old 01-29-2009, 11:33 AM Thread Starter
binski
binski's Avatar
Greetings all. I've started a trailer build based on a frame from a small generator trailer that I found. The base frame is all 1/4" material and solid (no decay). I'm interested in building up the tub sides using 1" square stock and then adding the skin material on the outside of the tub frame.
Due to costs, I'd like to use 1/16" wall 1" sq tube for the tub frame. Any concerns over strength for this purpose?
I will post pictures as this progresses. The axle is square tube with simple squared U-bolts to the springs. It has 5x4.5 hubs already, so I'll match my Rubicon's Moabs on 31" tires for the trailer.
Appreciate any thoughts.
Binski
Binski
Christian Jeep Club Member 257
Red Jeep Club Member 245
binski is offline
post #2 of 5 Old 01-29-2009, 04:04 PM
Smtty58
Depends on what you want to use the trailer for. You can increase the strength of a sheet panel by putting a couple diagonal breaks (creases) in it.
90 YJ, 4.2, AX-15
86 K1500, 305, 700R4
Smtty58 is offline
post #3 of 5 Old 01-29-2009, 06:07 PM Thread Starter
binski
binski's Avatar
Originally Posted by Smtty58 View Post
Depends on what you want to use thr trailer for. You can increase the strength of a sheet panel by putting a couple diagonal breaks (creases) in it.
Thanks for the tip on the skin ... don't know what I'll use there yet. My question is whether or not the 1/16 wall 1" sq tubing would be sufficient for the tub frame. Generally it will be a trailer to haul camping gear and should not exceed 1500 lbs total.
Binski
Binski
binski is offline
post #4 of 5 Old 01-30-2009, 04:23 PM
mudwhoreTJ
I say go for it... and in the case that it breaks... DUCT TAPE!!!!!!!
mudwhoreTJ is offline
post #5 of 5 Old 01-30-2009, 07:12 PM
timatoe
timatoe's Avatar
By "tub frame" you mean just the sides of the trailer right? Not any actual load bearing surface? If that's the case I think you'd be fine, but can't imagine the total savings would be that much between the 1/16 and 1/8 tube.
timatoe is offline
m416 trailer build gixxerphil General Jeep & Off-Road Equipment 83 03-29-2013 04:09 PM
Trailer build almost complete! binski Fabrication Shop 17 09-06-2009 12:14 PM
Build Trailer Using Trailer House Axles?? jsc7002 Fabrication Shop 5 07-19-2009 06:43 PM
Offroad Trailer Build! dawsonc61 Fabrication Shop 27 10-09-2008 10:41 PM
Anybody build a trailer? k8ysv Fabrication Shop 5 07-22-2005 10:04 PM
