Trackbar joint size 3/4"? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Trackbar joint size 3/4"?
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line50" LED CREE Light Bar Pair With Wiring KitTeraflex JK LCG PRE-RUNNER KIT! ULTIMATE OFF ROAD PERFORMA
Unread 03-31-2015, 10:10 AM   #1
Hussler
1992 XJ Cherokee
Pretty straightforward, Would a 3/4" thick shaft johnny joint be too weak for a trackbar? What did you use?
Hussler is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 09:38 AM   #2
jaspepp
i used a the johnny joint with a 3/4" shank and a 5/8" through bolt (I believe it was 1.625" wide). I think currie called it a narrow 2". had it in for 2+ years and haven't had any issues
"Idaho sucks!!!! Tell California"
jaspepp is offline   Reply With Quote Quick reply to this message
Unread 04-02-2015, 12:40 PM   #3
Hussler
1992 XJ Cherokee
Thanks, that's what I ended up ordering. I forgot I had a Rubicon express track bar on there already. Sure enough, 3/4" heim. So two 3/4 jjs is what I ordered
