Tow bar - high strength - JeepForum.com
post #1 of 2 Old 07-22-2011, 12:56 PM Thread Starter
martinCT
Just finished, build 10mm steel brackets, fixed at existing holes in TJ frame.
3 fixing points form each side of frame.
Main rod is 50x50x4.5mm square tube, removable receiver made of 6 mm steel plates, bolted with 4 x 8.8 grade screws at main rod...and adjustable-removable height hook...all deep galanized and powdercoated black.
Tested over weekend, works fine...
For elctrical part, I used 7 pin connector, and spliced wires form both back lights...
Only is missing proper lockable bolt – will make next week
It is another of my projects for add-on without drilling, welding or spoiling anything on original Jeep chassis or body....when you take add-on off--like newer bin there...
martinCT is offline
post #2 of 2 Old 07-22-2011, 03:34 PM
Jamesbbh
Nicely done!
Build thread (sorta)
Random stuff I've made thread
Jamesbbh is offline
8.8 strength airframer Engines & Drivetrain 1 07-19-2011 11:51 AM
Strength of a 12 bolt GraKee99 Engines & Drivetrain 1 06-13-2010 01:45 PM
gm 12 bolt strength BionicOnion Engines & Drivetrain 1 05-11-2009 05:30 PM
's about bp and strength NOTQUITEMUSASHI General Jeep & Off-Road Equipment 10 11-07-2005 02:12 AM
strength of frame jmsjeep General Jeep & Off-Road Equipment 2 05-15-2001 09:38 PM
