Tomb Raider's Shop - Page 11 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Fabrication Shop > Tomb Raider's Shop
ROCKRIDGE4WD Introduces a NEW Jeep Wrangler JK *led* tail Nitro Gear Packages Now Available at Rockridge 4wdMarch Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATE
Unread 08-13-2013, 09:34 PM   #151
8pitcher
Originally Posted by Helldorado Customs
Another customer pic ! Thanks Jeremy !!
How much for that bumper?
[URL="http://groups.jeepforum.com/built-not-bought/"][COLOR="Black"]Built Not Bought #640[/COLOR][/URL][/FONT][/SIZE][/COLOR][/CENTER][/COLOR]
8pitcher is offline   Reply With Quote Quick reply to this message
Unread 08-14-2013, 10:04 AM   #152
Helldorado Customs
Addicted...
Helldorado Customs's Avatar
http://store.helldoradocustoms.com/index.php/jk.html
I like to build stuff. Want to know what I build, you can google it HERE
Helldorado Customs is offline   Reply With Quote Quick reply to this message
Unread 08-15-2013, 05:18 AM   #153
Helldorado Customs
Addicted...
Some Dana 60 axle tube brackets for a customer.....the swag offroad brake press works awesome. As you can see, you can follow on instagram as well
Unread 08-15-2013, 09:25 PM   #154
Helldorado Customs
Addicted...
Some trick tabs:
and XJ brackets:
Unread 08-16-2013, 09:36 AM   #155
SadDayPanda
SadDayPanda's Avatar
XJ brackets for what?
Nice tabs
87, 93, 95 YJ
92, 98 XJ
87 J10
SadDayPanda is offline   Reply With Quote Quick reply to this message
Unread 08-16-2013, 09:53 AM   #156
Helldorado Customs
Addicted...
Nice tabs
Spoken from a guy whose never wheeled a cherokee
Frame support brackets for those that want a winch bumper on their XJ and not tear the thin unibody sheetmetal off
Unread 08-16-2013, 11:03 AM   #157
SadDayPanda
True story
87, 93, 95 YJ
92, 98 XJ
87 J10
Unread 08-25-2013, 07:35 PM   #158
Helldorado Customs
Addicted...
Buddy is doing an LM7 swap in his range rover and needed a custom crank sensor ring since the factory one would no longer work for the application.
Sent pics and measurements of what he needed...
Original:
So we design the new smaller one that will go on the front of the crank pulley:
After a little trial and error on steel thickness, we ended up with some 16 gauge. Had to turn the plasma down to the lowest setting of 25 amps to cut it with minimal dross and warping.
After cutting and some clean up, you can see the pulley here as well:
Then bent up and next to the original:
Was my first time using the "polar array" function in the cad software, fun project...
Cheers !!
Unread 09-06-2013, 02:39 PM   #159
Helldorado Customs
Addicted...
Unread 09-14-2013, 02:46 PM   #160
Helldorado Customs
Addicted...
Unread 11-10-2013, 07:15 PM   #161
Helldorado Customs
Addicted...
Been crazy busy with my "day job"....but, even with that...I'm deciding to make the plunge.
-Insert jefferson's theme song here-
Moving in Dec 1:
2 Bays with large overhead doors
2 offices with front "showroom"
Bathroom....thank god
Will need to get 220v outlets put in, but shouldn't be an issue since it has 200amp service. Oh...and a couch for when I screw up at home
Unread 11-13-2013, 06:31 PM   #162
Helldorado Customs
Addicted...
Trying to finish up projects before getting my move on. Gentleman brought a sweet *** CJ-8 Scrambler that had been completely restored....and I mean EVERY nut and bolt replaced. Best of all...was OD Green. He wanted a tunnel cover since he had went to an automatic behind the AMC 401 big block he stuffed in there So we fixed that up. He also wanted a simple rear bumper similar to the smittybilt YJ rear bumper. Sooo....we are fixin that up as well !
Unread 11-19-2013, 05:49 PM   #163
Helldorado Customs
Addicted...
Picked up the keys today to the new shop. Pulled the Jeep into the front and back bays for space reference. Still need 220v, but should start moving the small stuff this week/weekend.
Unread 11-19-2013, 06:09 PM   #164
AtTheHelm
Congratulations on the new shop! Looks like lots of space.
AtTheHelm is offline   Reply With Quote Quick reply to this message
Unread 11-20-2013, 06:33 AM   #165
zarnold
^ x2
zarnold is offline   Reply With Quote Quick reply to this message
