Tomb Raider's Shop - Page 11 - JeepForum.com
post #151 of 206 Old 08-13-2013, 10:34 PM
8pitcher
8pitcher's Avatar
Originally Posted by Helldorado Customs
Another customer pic ! Thanks Jeremy !!
How much for that bumper?
8pitcher is offline
post #152 of 206 Old 08-14-2013, 11:04 AM Thread Starter
Tomb Raider
Addicted...
Tomb Raider's Avatar
http://store.helldoradocustoms.com/index.php/jk.html
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #153 of 206 Old 08-15-2013, 06:18 AM Thread Starter
Tomb Raider
Addicted...
Some Dana 60 axle tube brackets for a customer.....the swag offroad brake press works awesome. As you can see, you can follow on instagram as well
post #154 of 206 Old 08-15-2013, 10:25 PM Thread Starter
Tomb Raider
Addicted...
Some trick tabs:
and XJ brackets:
post #155 of 206 Old 08-16-2013, 10:36 AM
SadDayPanda
XJ brackets for what?
Nice tabs
87, 93, 95 YJ
92, 98 XJ
87 J10
SadDayPanda is offline
post #156 of 206 Old 08-16-2013, 10:53 AM Thread Starter
Tomb Raider
Addicted...
Nice tabs
Spoken from a guy whose never wheeled a cherokee
Frame support brackets for those that want a winch bumper on their XJ and not tear the thin unibody sheetmetal off
post #157 of 206 Old 08-16-2013, 12:03 PM
SadDayPanda
True story
87, 93, 95 YJ
92, 98 XJ
87 J10
post #158 of 206 Old 08-25-2013, 08:35 PM Thread Starter
Tomb Raider
Addicted...
Buddy is doing an LM7 swap in his range rover and needed a custom crank sensor ring since the factory one would no longer work for the application.
Sent pics and measurements of what he needed...
Original:
So we design the new smaller one that will go on the front of the crank pulley:
After a little trial and error on steel thickness, we ended up with some 16 gauge. Had to turn the plasma down to the lowest setting of 25 amps to cut it with minimal dross and warping.
After cutting and some clean up, you can see the pulley here as well:
Then bent up and next to the original:
Was my first time using the "polar array" function in the cad software, fun project...
Cheers !!
post #159 of 206 Old 09-06-2013, 03:39 PM Thread Starter
Tomb Raider
Addicted...
post #160 of 206 Old 09-14-2013, 03:46 PM Thread Starter
Tomb Raider
Addicted...
post #161 of 206 Old 11-10-2013, 08:15 PM Thread Starter
Tomb Raider
Addicted...
Been crazy busy with my "day job"....but, even with that...I'm deciding to make the plunge.
-Insert jefferson's theme song here-
Moving in Dec 1:
2 Bays with large overhead doors
2 offices with front "showroom"
Bathroom....thank god
Will need to get 220v outlets put in, but shouldn't be an issue since it has 200amp service. Oh...and a couch for when I screw up at home
post #162 of 206 Old 11-13-2013, 07:31 PM Thread Starter
Tomb Raider
Addicted...
Trying to finish up projects before getting my move on. Gentleman brought a sweet *** CJ-8 Scrambler that had been completely restored....and I mean EVERY nut and bolt replaced. Best of all...was OD Green. He wanted a tunnel cover since he had went to an automatic behind the AMC 401 big block he stuffed in there So we fixed that up. He also wanted a simple rear bumper similar to the smittybilt YJ rear bumper. Sooo....we are fixin that up as well !
post #163 of 206 Old 11-19-2013, 06:49 PM Thread Starter
Tomb Raider
Addicted...
Picked up the keys today to the new shop. Pulled the Jeep into the front and back bays for space reference. Still need 220v, but should start moving the small stuff this week/weekend.
post #164 of 206 Old 11-19-2013, 07:09 PM
AtTheHelm
Congratulations on the new shop! Looks like lots of space.
AtTheHelm is offline
post #165 of 206 Old 11-20-2013, 07:33 AM
zarnold
^ x2
zarnold is online now
