TJ Wrangler trailer build . - Page 9 - JeepForum.com
post #121 of 243 Old 07-16-2013, 10:40 PM Thread Starter
G Beasley
Originally Posted by green50gt View Post
Looking good! You are way more motivated than I am, but I did touch mine tonight.. I moved it to mow.
Its getting close to being done and that is motivating me .
I hadnt considered that this thing is getting close to being one more thing to mow around .
Todays progress .
This is what 5 minutes of Kleen Strip aircraft stripper did . The yellow is all gone , tomorrow it will get cleaned then painted .
The front panel is tacked in place . Initially it was going to be removeable , but once it is LineX'd its not coming out so I went ahead and welded it in. Between seam sealing the front edge and LineX'ing the backside the front panel should be pretty weather resistant .
The tub is clean and ready for seam sealer . It took a lot of scrubbing to get all of the grinding dust out .
Lastly I started cutting out the trim for the old wheelwells . The plan is to cut and roll the angle around the radius to clean up the edges .
In addition to working on the trailer today I had both J trucks apart and I worked on them as the trailer was drying . It was hot as heck , but Kimbo kept the ice water rolling out to me .
G Beasley is offline
post #122 of 243 Old 07-18-2013, 05:29 PM Thread Starter
G Beasley
The trailer is seam sealed inside , and on the front filler panel .
The final trim is cut , unfortunately I ran out of angle .
I feel like the trailer is complete enough to go get it inspected tomorrow morning ... wish me luck
post #123 of 243 Old 07-18-2013, 09:57 PM Thread Starter
G Beasley
Tonights progress .
1st full coat of paint is on . Tomorrow I will wet sand the entire trailer and put down the second coat . It will get much darker on the second and third coats if cures like the test section did .
More first coat pics .
Welded up the trim bracket . Tomorrow I need to go get some more angle to finish the trim and make a hinge mount up front .
Not sure if I will make it to the inspection station tomorrow morning after all . Theres still a lot of little stuff to do before I take it over , and I would rather put more time into labor than go over and fail .
post #124 of 243 Old 07-18-2013, 10:30 PM
Tomb Raider
Addicted...
Tomb Raider's Avatar
Looks awesome.
I like to build stuff. Want to know what I build, you can google it
Tomb Raider is offline
post #125 of 243 Old 07-19-2013, 09:56 PM Thread Starter
G Beasley
Originally Posted by Helldorado Customs View Post
Looks awesome.
Thanks , its nice to see it almost towable
Today there was more sanding , but that allowed me to shoot the second coat of paint on the trailer .
I used aircraft stripper and picks to clean the tailgate and there was no getting it 100% clean . It looked ok , but a quick phone call found a guy that was willing to sand blast it for $20 . This is what it looked like when I picked it up , there will be no more airplane stripper at this house !
The first coat of primer and paint are on , it needs a lot of wet sanding to slick up like the rest of the paint .
I thought blasting the hinges might make them bind up , but I figured what the heck they cant get worse. Surprisingly enough they pivot much smoother now and with a little oil they should be buttery smooth . The blasted surface takes primer and paint so nicely that I am motivated to get an even bigger blast cabinet so that I can blast larger items .
Close up of the second coat of paint . It is starting to shine a little more and its getting much darker . Tomorrow I will wet sand again , and I think the third coat of paint is going to be just about right ... or at least I hope so
Last paint picture for the evening . There is no way I could do paint and body for a living , it requires entirely too much patience
post #126 of 243 Old 07-21-2013, 09:20 AM Thread Starter
G Beasley
Late night yesterday delayed my posting ... I was beat !
The paint looks good everywhere except the front panel , so I started putting everything back together . The flares were terribly faded so after I trimmed them to fit I used a heat gun to turn them black again .
You can see the difference in the flare in this picture . I was surprised at how well the heat gun trick worked . The process left a little blotchiness , but overall the flares look much better now than before . I still need to shoot another coat of paint on the tailgate , but I may leave that until I shoot car paint .
Definitely need another coat on the front panel .
Once its buffed I think a lot of the blotchiness will go away .
This is it for now , more this afternoon .
post #127 of 243 Old 07-22-2013, 07:38 AM Thread Starter
G Beasley
Yesterday I took the trailer out for its maiden run to see how it would tow on the road . When I first finished the tub I took it around the yard , but this was the first time I had it over 10 mph . I didnt know what to expect with it at speed , but it towed great. There was no hopping or wagging and best of all it was quiet .
You can see in this picture how much the trailer tub needs to be raised . Its not terrible and the 33's should make it sit about level with the LJ . Once the LJ gets 35's I think a spring over on the trailer will allow enough height to put 35's on the trailer with plenty of clearance .
Thats all the fabrication for now. I am off to work for the next six weeks , once I get back I will start working on the tonneau cover .
post #128 of 243 Old 07-22-2013, 07:46 AM
Tomb Raider
Addicted...
Thanks for sharing ! Turned out awesome.
post #129 of 243 Old 07-27-2013, 10:44 PM Thread Starter
G Beasley
Thanks for the kind words . Its towable now, but still needs some work . Next up will be the steel tonneau , then Line-X and finally a pro paint job. Oh and I cant forget the 35s on matching wheels .
post #130 of 243 Old 08-24-2013, 08:53 PM Thread Starter
G Beasley
Almost ready to go to the "real" paint shop .
Heres the trim piece welded up and ready to cover the rough edge of the old wheel well .
Trim piece in place .
Hard to see , but both trim pieces are in place .
This is where it gets tricky , this is a picture of the hinge mount . In this position I think its going to catch water and hold it .
I think that I am going to reverse it and have it face forward . This way with a little seam sealer it should seal up well and allow for a solid mounting point for the tonneau hinge .
Basically I will mount the angle opposite of this . More work tomorrow afternoon , its going to be close getting it ready for the trip .
post #131 of 243 Old 08-25-2013, 08:24 PM Thread Starter
G Beasley
The tailgate latches are complete , all thats left is the aforementioned hinge mount for the tonneau . After some thinking and measuring I came up with what I think is a pretty simple solution for the latches .
A piece of barstock happened to be laying on the counter and it was the perfect size for the latch to close onto .
Heres the barstock in place .
A few bends in the vice made for a good stop / catch for the latch .
And a nice out of focus picture of the tailgate latched .
post #132 of 243 Old 09-08-2013, 09:56 PM
aw12345
Pretty darn nice fab work Greg, looks like it will be all dialed in for the next big trip.
You will have a ball dragging it up the Dusy. about 30 miles of continues offroad action
aw12345 is offline
post #133 of 243 Old 09-09-2013, 07:48 PM Thread Starter
G Beasley
Thanks Art , it is going to make camping much easier as we cross the country as we wont have to be so compact . And with water on board and food we can stop wherever the notion hits us .
Whats this for and how does it relate to this thread ? See below ...
Heres the tub loaded up on the apparatus and ready to go to Hendrix's . The cribbing will keep the tub secure on the way home so it stays pretty .
post #134 of 243 Old 09-10-2013, 07:18 PM Thread Starter
G Beasley
Hendrix has gone buck wild on the tub ...
post #135 of 243 Old 09-11-2013, 08:16 AM
green50gt
green50gt's Avatar
Awww, no way, no fair! That thing is going to look amazing when he's done with it!
green50gt is offline
