TJ Wrangler trailer build . - Page 15 - JeepForum.com
post #211 of 243 Old 04-19-2014, 09:43 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
Originally Posted by G Beasley
The 3 M clear is on the list for Monday when I visit my local sound shop / neat stuff supplier . I also ordered the basket , it went down in price while I was gone to $93 !
Awesome, just didn't want you to get and sand blasting on the front of that super duper trailer.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #212 of 243 Old 04-19-2014, 09:46 PM Thread Starter
G Beasley
I am taking good care of your paint , though it is dirty as heck right now . Once it warms up I will wash and wax it .
G Beasley is offline
post #213 of 243 Old 04-20-2014, 06:12 PM
NashvilleTJ
I miss the snow...
NashvilleTJ's Avatar
Top looks great, Greg. Nice skill with the grinder - I always wind up gouging when I try to do finish work like that.
Jeff
NashvilleTJ is offline
post #214 of 243 Old 04-20-2014, 07:41 PM Thread Starter
G Beasley
Jeff
Thanks , I think it comes from all the years of sanding boats for my dad . We weren't allowed to mess up many while we were learning . So my brother and I both have a soft touch with sanders/grinders .
post #215 of 243 Old 04-23-2014, 09:23 PM Thread Starter
G Beasley
Still working on collecting parts for the new hitch assembly but I did have a few things show up today . I ordered a Highland basket from Amazon for $93 and I wasnt sure what to expect . I am happy to report that it went together easily and seems to be well made . I dont know that I would load it with the rated weight of 150 lbs , but it should carry all the beach stuff for the kids with no problem.
The three sections all laid out . It was extremely well packaged , with no visible damage anywhere .
The back half slid in perfectly as did the front . Then self tapping screws hold it together .
It comes with nice heavy hardware to attach it to your vehicle or trailer .
These rubber sleeves roll over the joints to help waterproof the rack . I suppose they work , but I will most likely take it back apart and weld up the joints .
All assembled .
I test fit it on Kimbo's WJ .
Here it is from the back with some custom wood mounting blocks .
And these are the locks and where they are going to go on the vertical flange .
Stickered up fairing and the beer of the day . I dont care for most IPA's , but I like this one a lot .
From the rear with the cargo net in place .I am going to get rid of the yellow plastic clips and replace them with black carabiners .
And we had John aka ECoast over and smoked / BBQ's burgers and red snap hot dogs . It was a good end to a great day .
post #216 of 243 Old 04-25-2014, 10:57 AM
bobdog
I picked up a HF tongue box today .
It fits great , but the cooler I got is a 1/2" too tall to clear the tonneau. Back to the drawing board on that one .
I've had mine a for a couple of years now and love it. Perfect size and fits a good bit of stuff like tools, extra oil, tire kit, etc.
Black Jeep Society
New Mexico Jeep Club
Atheist Jeep Society
Micro-Trailer Club
bobdog is offline
post #217 of 243 Old 04-25-2014, 08:53 PM Thread Starter
G Beasley
It was an odd day with the weather and lack of productivity but I found a smoking deal on a Yakima rack for the trailer! It was a little too tall in the stock setup , but is perfect with the towers removed . I do plan on narrowing the bars a little before its fully installed .
post #218 of 243 Old 04-28-2014, 11:16 PM Thread Starter
G Beasley
Tonight I got to work on the tonneau . First up was to measure 5 times and then drill the holes . I was nervous about drilling the tonneau and thats why I kept measuring . I am by no means a perfectionist , but all four holes squared up within 1/64th . This trailer is going to end up being the most precise thing I have ever built.
Once the holes were drilled I ran the bolt through the angle support and into the yakima rack mounts. This served two purposes . One was to strengthen the top and the second purpose is to provide a mount for the lifting strut .
Once everything was mounted to the tonneau I made two lower mounting brackets for the struts .
And then it was time for the voodoo math magic to get the extended length and the angles to all work together . The good news is that I got the max height with good working angles . The bad news is that the struts I picked are rated at 150lbs and one arm attached seems perfect . When both arms are attached it wont stay shut . So tommorrow I am going to call AVM and see what strut has the same lenght with less lifting force .
With just the one strut installed it feels just about perfect and allows for plenty of room to get in and out of the trailer .
And heres the catapault/tonneau with both struts . It is nice to be able to get rid of the stick !
post #219 of 243 Old 04-29-2014, 09:21 PM Thread Starter
G Beasley
No luck on the struts today , still hunting for a pair that are 14" compressed and 21"extended with 40-50lbs of lifting force .
I did get to Tractor supply for some hitch supplies after the strut debacle today. I picked up a 1" bolt , nut , collar and centering ball . Then they got chucked !
The centering collar and bolt turned down and ready to insert into the tubing . The collar fits inside of the 1.75 tubing perfectly , though I did turn the bolt down a little bit more to make sure it wouldnt bind . Once everything is in place I will weld the collar in on the end and through plug welds .
This spacer will be replaced with another centering ball .
And this shows what the end result of hitch 2.0 will look like .
post #220 of 243 Old 04-29-2014, 09:39 PM
Hendrix
TJOTY 2013
Hendrix's Avatar
This MB I am working on at work as a pair of dual stage struts on the hood. You can open the hood a little or straight up.
K.C.C.O.
Carpe Diem
Hendrix is offline
post #221 of 243 Old 04-29-2014, 09:55 PM Thread Starter
G Beasley
Year and model ? What type ends do they have ?
post #222 of 243 Old 04-30-2014, 08:44 PM Thread Starter
G Beasley
Made some more progress on the hitch , I think all I have left to order is a threaded insert and then I can weld it all up .
I wanted to use a bronze washer between the two halves , but it was impossible to find locally . The local machine shop sold me a block of self lubricating dense plastic that may be a remnant from chernobyl . I am not kidding this stuff is almost impossible to cut , but with slow speeds I was able to make a washer .
I used a 1.75"hole saw to make the outer cut , and then a 1" hole saw to make the inner cut . Then I flipped it on its side and made a vertical cut with the band saw. Once that was done the washer fell out .
It looks rough , but smoothed out nicely with a little sanding .
When I get back from New Jersey I will finish this and the tonneau up and move on to outfitting the trailer for trips .
post #223 of 243 Old 04-30-2014, 09:31 PM Thread Starter
G Beasley
https://www.youtube.com/watch?v=uNHx0dhZy4o
The new struts work great , and should still lift a couple of bikes up no problem . I am going to add an X brace underneath to stiffen the tonneau up a little , but its so nice having the trailer almost ready to go .
post #224 of 243 Old 04-30-2014, 10:09 PM
Sahara707
Here's a picture of my 3-Axis hitch. Fun project.
trailer build. http://www.jeepforum.com/forum/f27/a...build-1558519/
Sahara707 is offline
post #225 of 243 Old 05-01-2014, 04:34 AM Thread Starter
G Beasley
Thats similar to what I am building . I will look through your thread to see where you got the bearings for the receiver hitch mount . How does it tow ?
