TJ Wrangler trailer build . - JeepForum.com
post #1 of 243 Old 10-15-2012, 08:28 PM Thread Starter
G Beasley
Over the last two years I managed to wrangle up (terrible ) two wrangler tubs that had been in front end collisions . Just recently I have started building a trailer . This was almost a thread within a thread on my LJ build , so here it is on its own .
These are the two tubs I started with . I think I need larger tires
With a little follow the sharpie and a fine tooth blade on my sawzall this is what the white tub looked like all ready to be welded .
Getting the bulkheads out was tough . The method that worked best for me was to cut them in sections then wiggle them back and forth with a pair of vice grips to break them loose .
Blue tub getting cleaned and ready to be cut .
Both halves cut and fitted . At this point I used a mild flapper wheel to prep all the weld surfaces .
I dont have pictures of the process , but I used a ratchet strap to keep the two halves tight together as I was tacking them together .
Removing the lower crossmember spot welds was terrible , but it was worth it . By removing the crossmember on the blue section I was able to butt the two floor surfaces together over the crossmember on the white section.
Welded and flappered . I ran my Miller 210 on level 2 and wire speed of 20. I found the jeep sheetmetal to be very forgiving , and with enough stitching I got minimal warpage .
Here you can see where I was able to land the two floors on the same crossmember . It was a little planning and a lot of luck .
All welded up , and it came out pretty nice .
G Beasley is offline
post #2 of 243 Old 10-15-2012, 08:32 PM Thread Starter
G Beasley
I have the 2"x2" box tube for the frame at the house and I hope to start the frame when I am home next week . I will also be cutting the old fender well corners on the blue section out and welding in flooring that will come from the extra flooring left from the blue tub . The end goal of this is to have a trailer that we can camp out of and hopefully it will match the LJ .
More pics to come next week .
post #3 of 243 Old 10-15-2012, 10:15 PM
2000-TJ
I like it so far!
2000 TJ 4.0 Automatic
2002 F-250 Tow Rig
Mark Wood Carpentry and Metal Fab
http://www.facebook.com/pages/Mark-Wood-Carpentry/117967248267233?ref=stream
2000-TJ is offline
post #4 of 243 Old 11-26-2012, 09:26 PM Thread Starter
G Beasley
Made a little progress on the Jeep tub trailer today .
Most of the frame is cut and ready to be welded . Still looking for hockey pucks to use as body mounts , not too easy to find around here !
Tomorrow I plan on welding up the frame and hopefully mounting the frame to the tub . The Savvy corners also came in today , but I think they are going to wait until it warms up and I can paint them to match my LJ .
post #5 of 243 Old 11-27-2012, 01:33 PM
Molonlabemike
I'm so in on this, great work bud!
Molon Labe
Molonlabemike is offline
post #6 of 243 Old 11-27-2012, 02:27 PM
Doubblea
Loking good! im following this one.
"The beauty of the Second Amendment is that it will not be needed until they try to take it." -Thomas Jefferson
Doubblea is offline
post #7 of 243 Old 11-27-2012, 07:30 PM Thread Starter
G Beasley
Thanks , its been fun so far .
I hope to have it rolling this week , still a ways to go though .
Crossmember bolted in place and the corners cut off .
Tacking it all up .
Beginning of the welds .
Hannah monkey the photographer / assistant approves .
The receiver tongue is marked up , just need to recess it through the front angle iron .
post #8 of 243 Old 11-27-2012, 09:54 PM
Molonlabemike
What are your plans for the axle? I'm thinking about building a trailer but trying to figure out if I will mod a harbor freight trailer or just build one from scratch. As always buddy, good work!
Molon Labe
post #9 of 243 Old 11-28-2012, 09:27 AM Thread Starter
G Beasley
Thanks for the encouragement , its motivating on a cold day like today !
Gspup has been helping me figure a lot of this out , and he has suggested a 2000 lb or so Reliable axle . They run a similar axle at Ruger Trailers http://rugertrailers.com/ . There is a monkey wrench in the works as I have a chance to pick up a free drop axle. I think I might give it a try installed upside down . The extra clearance in the middle would be sort of like a portal axle and theoretically should be less likely to hang up along the trail. If it doesnt work , I can get a reliable and replace it .
post #10 of 243 Old 11-28-2012, 05:40 PM
LJWrangler
G check these out http://www.trailerpart.com/halftorsionaxles.htm 2000# are $285 and come in a 5-4.5 bolt pattern. I have used them before and they work great just not sure what kind of budget you have! Awesome build so far
SILVER JEEP CLUB #71
My Build
LJWrangler is offline
post #11 of 243 Old 11-28-2012, 06:08 PM
mmbtv
Trailer is looking good!
Do you still have the fender wells from the dark tub?
mmbtv is offline
post #12 of 243 Old 11-28-2012, 06:52 PM
NOCHEEPGAS
1980 CJ5
Great project, wanting to do one for my CJ one day. a lot cheaper than 3K for an Aqualu trailer body. http://www.aqualu.com/jeep-cabs--boxes.html
Since it looks like you're keeping both tailgates you might want to consider a removeable tongue (think receiver hitch) that you can put at either end of the trailer.
NOCHEEPGAS is offline
post #13 of 243 Old 11-29-2012, 09:16 AM Thread Starter
G Beasley
With Christmas close at hand my budget is getting slim ! I have a free axle that I am going to run for now . If it doesnt work I will get a Reliable at a later date .
Yes I still have the rest of the blue tub , I am going to cut whats left of the floor out of it to fill in the corners of the trailer . Do you need fender wells ?
The Aqualus look awesome and they are way nicer than what I am making, but the $150 or so I have in my tub more than makes up for the imperfections . Right now the plan is to have both tailgates , but I think the front one may be bolted in place . If you look at the picture below the tube in the middle at the front is receiver tube , so that the tongue is detachable . On the rear I will be able to attach it to the receiver in the bumper .
post #14 of 243 Old 11-29-2012, 09:22 AM Thread Starter
G Beasley
I made a little progress yesterday , hope to get more done this afternoon .
I mis-measured my front mounts and the small amount I needed to cut off was not agreeing with the band saw . The vice grips kept the
angle in place and I got a nice square cut versus using the sawzall .
The front mounts are cut , fitted , bolted and ready to weld . The other four mounts are cut and waiting to be tacked in place . If I can pick up the axle tonight I might be able to have this on wheels tomorrow afternoon .
post #15 of 243 Old 11-29-2012, 05:02 PM
NOCHEEPGAS
1980 CJ5
Wow, $150.00! Cant touch a tub to cut up around these parts for less than 5 bills, that makes it 1K for two of them, which almost make the Aqualu's worth the money.
