-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   TJ Wrangler trailer build . (http://www.jeepforum.com/forum/f37/tj-wrangler-trailer-build-1427938/)
G Beasley 10-15-2012 08:28 PM
Over the last two years I managed to wrangle up (terrible ) two wrangler tubs that had been in front end collisions . Just recently I have started building a trailer . This was almost a thread within a thread on my LJ build , so here it is on its own .
http://i34.photobucket.com/albums/d1...psddc28213.jpg
These are the two tubs I started with . I think I need larger tires :D
http://i34.photobucket.com/albums/d1...vis/tub007.jpg
With a little follow the sharpie and a fine tooth blade on my sawzall this is what the white tub looked like all ready to be welded .
http://i34.photobucket.com/albums/d1...vis/tub008.jpg
Getting the bulkheads out was tough . The method that worked best for me was to cut them in sections then wiggle them back and forth with a pair of vice grips to break them loose .
http://i34.photobucket.com/albums/d1...vis/tub009.jpg
Blue tub getting cleaned and ready to be cut .
http://i34.photobucket.com/albums/d1...rafting003.jpg
http://i34.photobucket.com/albums/d1...rafting005.jpg
Both halves cut and fitted . At this point I used a mild flapper wheel to prep all the weld surfaces .
http://i34.photobucket.com/albums/d1...rafting006.jpg
I dont have pictures of the process , but I used a ratchet strap to keep the two halves tight together as I was tacking them together .
http://i34.photobucket.com/albums/d1...rafting007.jpg
Removing the lower crossmember spot welds was terrible , but it was worth it . By removing the crossmember on the blue section I was able to butt the two floor surfaces together over the crossmember on the white section.
http://i34.photobucket.com/albums/d1...rafting014.jpg
Welded and flappered . I ran my Miller 210 on level 2 and wire speed of 20. I found the jeep sheetmetal to be very forgiving , and with enough stitching I got minimal warpage .
http://i34.photobucket.com/albums/d1...rafting011.jpg
http://i34.photobucket.com/albums/d1...rafting012.jpg
Here you can see where I was able to land the two floors on the same crossmember . It was a little planning and a lot of luck .
http://i34.photobucket.com/albums/d1...rafting008.jpg
All welded up , and it came out pretty nice .
G Beasley 10-15-2012 08:32 PM
I have the 2"x2" box tube for the frame at the house and I hope to start the frame when I am home next week . I will also be cutting the old fender well corners on the blue section out and welding in flooring that will come from the extra flooring left from the blue tub . The end goal of this is to have a trailer that we can camp out of and hopefully it will match the LJ .
More pics to come next week .
2000-TJ 10-15-2012 10:15 PM
I like it so far!
G Beasley 11-26-2012 09:26 PM
Made a little progress on the Jeep tub trailer today .
http://i34.photobucket.com/albums/d1...epframe030.jpg
http://i34.photobucket.com/albums/d1...epframe031.jpg
http://i34.photobucket.com/albums/d1...epframe034.jpg
Most of the frame is cut and ready to be welded . Still looking for hockey pucks to use as body mounts , not too easy to find around here !
Tomorrow I plan on welding up the frame and hopefully mounting the frame to the tub . The Savvy corners also came in today , but I think they are going to wait until it warms up and I can paint them to match my LJ .
Molonlabemike 11-27-2012 01:33 PM
I'm so in on this, great work bud!
Doubblea 11-27-2012 02:27 PM
Loking good! im following this one.
G Beasley 11-27-2012 07:30 PM
Thanks , its been fun so far .
I hope to have it rolling this week , still a ways to go though .
http://i34.photobucket.com/albums/d1...erframe005.jpg
Crossmember bolted in place and the corners cut off .
http://i34.photobucket.com/albums/d1...erframe006.jpg
Tacking it all up .
http://i34.photobucket.com/albums/d1...erframe018.jpg
Beginning of the welds .
http://i34.photobucket.com/albums/d1...erframe031.jpg
Hannah monkey the photographer / assistant approves .
http://i34.photobucket.com/albums/d1...erframe034.jpg
The receiver tongue is marked up , just need to recess it through the front angle iron .
Molonlabemike 11-27-2012 09:54 PM
What are your plans for the axle? I'm thinking about building a trailer but trying to figure out if I will mod a harbor freight trailer or just build one from scratch. As always buddy, good work!
G Beasley 11-28-2012 09:27 AM
Thanks for the encouragement , its motivating on a cold day like today !
Gspup has been helping me figure a lot of this out , and he has suggested a 2000 lb or so Reliable axle . They run a similar axle at Ruger Trailers http://rugertrailers.com/ . There is a monkey wrench in the works as I have a chance to pick up a free drop axle. I think I might give it a try installed upside down . The extra clearance in the middle would be sort of like a portal axle and theoretically should be less likely to hang up along the trail. If it doesnt work , I can get a reliable and replace it .
LJWrangler 11-28-2012 05:40 PM
G check these out http://www.trailerpart.com/halftorsionaxles.htm 2000# are $285 and come in a 5-4.5 bolt pattern. I have used them before and they work great just not sure what kind of budget you have! Awesome build so far
mmbtv 11-28-2012 06:08 PM
Trailer is looking good!
Do you still have the fender wells from the dark tub?
NOCHEEPGAS 11-28-2012 06:52 PM
Great project, wanting to do one for my CJ one day. a lot cheaper than 3K for an Aqualu trailer body. http://www.aqualu.com/jeep-cabs--boxes.html
Since it looks like you're keeping both tailgates you might want to consider a removeable tongue (think receiver hitch) that you can put at either end of the trailer.
G Beasley 11-29-2012 09:16 AM
With Christmas close at hand my budget is getting slim ! I have a free axle that I am going to run for now . If it doesnt work I will get a Reliable at a later date .
Yes I still have the rest of the blue tub , I am going to cut whats left of the floor out of it to fill in the corners of the trailer . Do you need fender wells ?
The Aqualus look awesome and they are way nicer than what I am making, but the $150 or so I have in my tub more than makes up for the imperfections . Right now the plan is to have both tailgates , but I think the front one may be bolted in place . If you look at the picture below the tube in the middle at the front is receiver tube , so that the tongue is detachable . On the rear I will be able to attach it to the receiver in the bumper . http://i34.photobucket.com/albums/d1...erframe034.jpg
G Beasley 11-29-2012 09:22 AM
I made a little progress yesterday , hope to get more done this afternoon .
http://i34.photobucket.com/albums/d1...lerdeux010.jpg
I mis-measured my front mounts and the small amount I needed to cut off was not agreeing with the band saw . The vice grips kept the
angle in place and I got a nice square cut versus using the sawzall .
http://i34.photobucket.com/albums/d1...lerdeux011.jpg
The front mounts are cut , fitted , bolted and ready to weld . The other four mounts are cut and waiting to be tacked in place . If I can pick up the axle tonight I might be able to have this on wheels tomorrow afternoon .
NOCHEEPGAS 11-29-2012 05:02 PM
Wow, $150.00! Cant touch a tub to cut up around these parts for less than 5 bills, that makes it 1K for two of them, which almost make the Aqualu's worth the money.
The time now is 09:30 PM.
