TJ switch panel - JeepForum.com
post #1 of 2 Old 06-14-2004, 09:23 PM Thread Starter
CETROV
CETROV's Avatar
TJ switch panel
Having the switches mounted above the rear view mirror for so long, and then replacing the mirror with the new compass, auto dim, temp reading compass I found that the switch box was just a little to big for the area. I thought of different locations for the switch panel and decided on this one. I don't have a need for an ashtray, (coin holder), and the other panel held the cigar lighter, fog light switch and some blanks for two other switches. I cut out the ashtray and removed the other half as it just bolts in. Then I cut some sheet metal and riveted it onto the frame. Then drilled 11 1/2 inch holes to hold the switches. I then hard wired a 3 way accessory outlet to the bottom of the panel and put a switch on it to turn it on and off, Then I added a 4th outlet to the right of this that is always on. I found that when running my GPS every time I turned of the ignition the GPS had to be restarted so I wanted to have a non switched outlet for this.
I wired in an accessory fuse box next to the original one to run the switch panel on short wires. I added a block for the negative wires. It is stuck to the back of the sheet metal insert, it has one main ground wire running to the body and then all the negative leads attach to it, it has 8 terminals.
Switches control or will control when done.
Front locker, Rear locker, Air Pump, Hella lights, Hella high beam and one for the low beam, spot lights, rock lights, back up flood lights, interior lights, and three left over for whatever.
97 TJ
CETROV is offline
post #2 of 2 Old 06-15-2004, 03:25 PM
doorocks
doorocks's Avatar
Nice Work Cetrov,
Would look even cleaner if you could incorporate the power terminals into it.
LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
Life is like walking into the No Chance Bar full of Future Darwin Stories........
More mods than a hillbilly's set of teeth..
doorocks is offline
My New YJ switch panel that I'm working on 92 Green YJ Audio, CB & Ham Radios, GPS, & Electrical 6 03-01-2012 04:51 PM
Switch Panel Design Scotch740 Fabrication Shop 21 09-24-2009 10:45 AM
how do I get to the switch panel in my tj bandit455 Audio, CB & Ham Radios, GPS, & Electrical 3 11-30-2008 06:44 AM
My switch panel Comanche_ General Jeep & Off-Road Equipment 0 08-29-2008 12:34 AM
Aux switch panel... neZZr Audio, CB & Ham Radios, GPS, & Electrical 21 05-16-2006 01:14 PM
