TJ roof rack corner armor questions and help? - JeepForum.com
post #1 of 10 Old 03-07-2016, 02:26 PM Thread Starter
whoppe
I am thinking of making a roof rack for my jeep tj. I just need a small rack to carry gear. I'm thinking of buying the full rear corner armor by barricade from extreme terrain and welding some square tubing to it front and rear. I'm gonna use this as kind of a receiver hitch for the rack frame so I can remove the rack when not in use. I am then thinking of building supports and a small rack that will drop into the receivers. Will this work or be too much wait on the corner armor? I am after something about the size of the back seat and truck for rack size. I have seen the racks that go on the swing out tire carrier but I feel like I already have too much weight back there with a 33" tire, hi lift and jerry cans. I also want something where the hard top is easily removable and I can fold the front windshield down without too much work. sorry for the bad drawings. Any help?
http://www.extremeterrain.com/barric...j-j100297.html
whoppe is offline
post #2 of 10 Old 03-08-2016, 08:09 AM Thread Starter
whoppe
bump
whoppe is offline
post #3 of 10 Old 03-09-2016, 06:47 AM
auswall
I'm also curious, would like to do the same thing for my hard top tj.
auswall is offline
post #4 of 10 Old 03-09-2016, 02:47 PM
mike_dippert
mike_dippert's Avatar
If the welds are strong enough, I don't see why weight would be an issue.
I would move the rear anchor points to the side so the support hoops can be the same size/interchangeable.
mike_dippert is offline
post #5 of 10 Old 03-11-2016, 10:09 AM
auswall
Originally Posted by mike_dippert
If the welds are strong enough, I don't see why weight would be an issue. I would move the rear anchor points to the side so the support hoops can be the same size/interchangeable.
Could you please explain this a little better or a picture possibly about the support hoops?
auswall is offline
post #6 of 10 Old 03-11-2016, 10:33 AM
mike_dippert
Most racks use hoops instead of just legs. They're a U shape that goes from the driver side to the passenger side. The basket part sits on top of the hoops.
post #7 of 10 Old 03-11-2016, 06:19 PM
auswall
you mean so the front and back hoop are equal in width? Gotcha 👌🏻
auswall is offline
post #8 of 10 Old 04-04-2016, 08:00 AM
Ross
delete double post
01 TJ, 34 Super Swaper 34x10.5 bias, Winch, locked, belly up, some armor, 4.0, 5spd
Ross is offline
post #9 of 10 Old 04-04-2016, 08:05 AM
Ross
Adding weight to the back can change how your TJ drives. Any weight past the rear axles changes things even move. The higher the weight is the more it changes things.
I have a small rack I made that hangs over the my windshield and far enough forward to allow me to take down my top while leaving the rack on. It isn't nearly as stout as the one you are planning. It is good for sleeping bags and chairs, bulky light stuff.
http://www.jeepforum.com/forum/f9/made-rack-tj-3672417/
Ross is offline
post #10 of 10 Old 04-06-2016, 09:24 AM
partegolkar
agreed with you
partegolkar is offline
