TJ rear bumper/ rear crossmember ideas - JeepForum.com
post #1 of 6 Old 07-04-2009, 01:44 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Since removing my factory skid plate, I'm toying with the idea of removing the rear bumper and cutting out the rear cross member and fabricating something there.
My idea is to cut out the rear cross member out
replacing it with a 2x4 box tube because my current bumper is my air tank.
I really would like to maintain my rear hitch receiver because i'm thinking about making a receiver mount tire carrier.
One problem that I'm thinking about is keeping the receiver mount and also recessing my tank between the frame rails to gain more interior storage.
any thoughts or ideas?
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 6 Old 07-04-2009, 10:52 PM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Here is a mockup I did for my Jeep. Rather than cut out the cross member, I'll just cut the "Ears" off the end of it. Then I'll use some nice big 4x4 angle and slide it up the frame rails. 1 Big hole for the body mount and a few smaller ones (not in the drawings below) for the bolts. Should be strong as hell.
Just something to think about. SHould be a lot easier than redoing the whole cross member, especially for those of us that still have the stock tank skid.
... an no sidewindin' bushwackin', hornswagglin' cracker croaker is gonna rouin me bishen cutter.
LOCKED UP is offline
post #3 of 6 Old 07-05-2009, 06:57 AM Thread Starter
JeepRocks86
Looks good, but i'm looking for a little less overhang in the rear.
For Sale:
post #4 of 6 Old 07-05-2009, 10:07 AM
LOCKED UP
Senior Web Wheeler
LOCKED UP's Avatar
2006 XK Commander
Are you running a spare tire?
Where is your gas tank?
That will actually flush up to the factory cross member so it will stick out a mere 2" (other than the hitch). You could certainly flush the hitch to the face and sink part of it into the factory cross member area, depending on where your gas tank is.
I asked about the spare because if you are running one you may want the receiver to sit there to help protect whatever your tire is on (factory spare mount or swing away spindle). God knows I rather take a hard knock on the receiver than bend up a spindle or tear up the tail gate.
If you are spareless and running a fuel cell in the "bed", then you absolutely can cut out the cross member and put in some box tube and make a roll pan kind of setup, but you may fond yourself dinging up the body back there. I personally like to have a little bit of bumper back there sticking out for that reason.
post #5 of 6 Old 07-05-2009, 07:27 PM
flatlander757
If you need less overhang in the rear stretch the wheelbase.
Just build a bumper for the crossmember and build some stout frame tie-ins. Hell my rear suspension is mounted off of mine and I have no doubt that it will be perfectly fine once I get some frame tie-ins from BESRK as I had one of his tire carrier/bumpers before and liked them(he actually welded the d-ring tabs and reciever onto my current bumper as well).
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
post #6 of 6 Old 07-05-2009, 07:50 PM Thread Starter
JeepRocks86
currently my cell is in the back, held in with 2 ratchet straps because I finished the install about 30 min before leaving for a wheeling trip a few weeks ago.
I plan to sink it between the frame rails though.
After thinking about it, I would probably be better off just leaving the rear cross member and building a flush mount bumper.
As for tire carrier, Usually I had the spare in the back where the seat would be. Needless to say, the first time in a long time I didn't take the spare, I had to send back to camp to get someone to bring it since I destroyed a steel rim.
For Sale:
CJ rear crossmember fab ideas chet44 Fabrication Shop 2 06-21-2009 06:46 AM
Rear storage bumper plans for review and ideas jgorm Fabrication Shop 19 07-03-2008 08:58 AM
Rear Crossmember tobias94yj Fabrication Shop 0 12-02-2006 05:18 PM
Where to find rear bumper w/integrated rear hitch in bumper? djaychris General Jeep & Off-Road Equipment 15 01-09-2006 07:29 PM
Rear Bumper Ideas jeepkid8037 Fabrication Shop 0 05-31-2005 10:50 AM
