TJ rear bumper build - JeepForum.com
post #1 of 22 Old 10-12-2012, 08:02 AM Thread Starter
2000-TJ
I started building a rear bumper for my 2000 TJ yesterday. Heres the materials I bought.
6' of 2"x4"x1/4" tube $41.57
6' of 1"x1"x1/8" tube $10.38
2' of 2 1/2'x2 1/2"x1/4" tube $12.14
4' of 1/4" Angle iron
3' of 1/4" channel
Bought both the angle and channel as scrap @ 0.40 cents a lb and came to a total of $5.60 I wish they had it all in scrap prices!
Total: $71.69
I know I wont need all of this but I always like to buy more than I need when I build something that I have never built.
2000 TJ 4.0 Automatic
2002 F-250 Tow Rig
Mark Wood Carpentry and Metal Fab
http://www.facebook.com/pages/Mark-Wood-Carpentry/117967248267233?ref=stream
2000-TJ is offline
post #2 of 22 Old 10-12-2012, 08:03 AM Thread Starter
2000-TJ
This is what I removed. These Items are for sale PM me for details.
2002 F-250 Tow Rig
2000-TJ is offline
post #3 of 22 Old 10-12-2012, 08:04 AM Thread Starter
2000-TJ
I plan to get alot further on it today so I can post some progress.
2002 F-250 Tow Rig
2000-TJ is offline
post #4 of 22 Old 10-12-2012, 10:02 AM Thread Starter
2000-TJ
So I got busy this mornin and started out by cutting the 2x4 tube to 55 inches in length and cut a triangle out of each end with a sawzall man I really need some tanks for my torch set or a plasma cutter but I make due.
2002 F-250 Tow Rig
2000-TJ is offline
post #5 of 22 Old 10-12-2012, 10:04 AM Thread Starter
2000-TJ
Then I clamped the ends and did some welding with my trusty Hobart TigMate.
2002 F-250 Tow Rig
2000-TJ is offline
post #6 of 22 Old 10-12-2012, 10:07 AM Thread Starter
2000-TJ
And did some grinding to smooth the welds.
2002 F-250 Tow Rig
2000-TJ is offline
post #7 of 22 Old 10-12-2012, 10:10 AM Thread Starter
2000-TJ
I had some uneven ends after welding and grinding so I squared them up with the chop saw.
2002 F-250 Tow Rig
2000-TJ is offline
post #8 of 22 Old 10-12-2012, 10:16 AM Thread Starter
2000-TJ
It ended up being 53 inches Because I didnt figure for having to square up the ends so it is 2 inches shorter than I had pland but I checked it and it will still work out good its 2 inches short of being as wide as the jeep but I will split the differance 1 inch on each side shouldnt matter.
2002 F-250 Tow Rig
2000-TJ is offline
post #9 of 22 Old 10-12-2012, 01:53 PM
jasonswelding
If the 2 1/2" tube is for a receiver, test fit a hitch in it. The seem on the inside may cause it to be to tight.
jasonswelding is offline
post #10 of 22 Old 10-12-2012, 05:06 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
You can take a file to the seam to smooth it down. Even so, the 1/4" wall receiver tube is gonna be a tight fit. Actual receiver tube is run over a mandrel to get the proper size.
Are you certain about the 53" length? I make my bumpers 58" wide and they're about 1" shy of the edge of the tub. Doesn't make a big difference if you're not going to run a swingarm. However if you do run a swingarm, the shorter length will make it difficult to place your pivot spindle and latch "outboard" of the tailgate (especially with the tapered bumper ends).
BESRK is offline
post #11 of 22 Old 10-12-2012, 05:15 PM Thread Starter
2000-TJ
I already tested it and it works.
2002 F-250 Tow Rig
2000-TJ is offline
post #12 of 22 Old 10-12-2012, 05:17 PM Thread Starter
2000-TJ
I will check it again tomorrow but I think it'll be fine 55 is the width of the tub so 53 should be ok
2002 F-250 Tow Rig
2000-TJ is offline
post #13 of 22 Old 10-12-2012, 07:03 PM
sailsurf7713
Looks good so far. I just started a rear crossmember and paid 67 dollars for 4x2x3/16" x 6' And had to order it online!
'99 SE: The "It could be worse..." jeep
Originally Posted by 97flexy View Post
...I say don't lift but CUT. :)
sailsurf7713 is offline
post #14 of 22 Old 10-13-2012, 06:37 AM Thread Starter
2000-TJ
yeah the place I get material from has the best prices I have ever seen only thing is they keep it outside so it gets a little rusty. but I can live with that for the prices !
2002 F-250 Tow Rig
2000-TJ is offline
post #15 of 22 Old 10-13-2012, 07:16 AM
jayrubicon
Love it man. Can't beat saying you but your own bumper nevermind saving hundreds of dollars
Sent from my iPhone while under my Jeep
jayrubicon is offline
