TJ Overhead Console Build Thread
| GR8TOPS Introduces the Exogate HD Tire Carrier | Truck-Lite's New LED Headlamp Series | RUBICON EXPRESS Lift Kits and Accessories Available at Bas |
#1 | |
Due to my lack of funds and Tuffy's overhead console being $400+, i decided to build my own console to house my stereo, cb, maxitrip auto comp., and a switch panel. Now i realize there will be some dispute about using plywood for the main body of the console, but i am a very adequate woodworker, so i decided to stick with what i know ( I didn't win the Construction student of the year award for doing nuthin' ! ). So the main issues i have heard with using wood for something like this are moisture and vibration. I used rocker guard over the whole thing, so moisture is not really an issue. Plus i gusseted (lol is that even a word??) quite will, so i dont think vibes will be a problem.
The design: Due to my inability to plan stuff in advance, i came up with the overall design and layout of the console during a random stroll through home depot with one of my buddies. the idea seemed fairly solid, so i picked up most of the needed materials at that point. The Materials: One sheet of plywood ( got it from the scrap section for 51 cents ) one 1"x1/8"x48" steel bar. ( had to get another one later, so two were needed ) one 8' piece of 1/8" c-channel aluminum....lots will be left over. just need 44.5" for the front crossmember that goes between the cage bars. a plethora of 1/4"x3/4"and1/2" bolts, with corresponding nuts and rubber washers for each about 6-8 larger bolts (cant recall the size at the moment) one 3'x2' sheet of galvanized steel (doesnt have to galvanized, but it was shiney.. ) some small screws, 1/2" i believe lots of primer and paint few cans of rocker guard waterproof/outdoor glue and a few other things i've probably forgotten but will add later. In total this cost me just less than $150 ( the paint accounts for a fair bit of it ) not including the switches, stereo, wiring, etc. Tools: hammer Assortment of saws: band saw, scroll saw, jig saw, hack saw are all good to have Screwdrivers Drill Drill bit set....everything from 3/16s to 1/2" (for both metal and wood)......drill press would've been nice a few files marking awl center punch sandpaper vice anvil was nice to smooth the edge of the freshly cut sheet metal tin snips and again, i've probably forgotten something that i can add later now, time for pictures getting started ![]() planning stuff out ![]() cutting one of the sides ![]() the two identical sides next to each other ![]() The maxitrip ![]() a quick mock up of the stereo and computer ![]() Glueing.....the more clamps the better ![]() Deciding what to do for the switch panel ![]() I drilled 4 holes, one at each corner of where the switch panel housing had to be cut out. ![]() Mock up of the switch panel (though there will be 8 switches when it is done...one for the coffee maker, passenger ejection, oil slick....etc ) ![]() cont....
A 6spd makes it a race car right? |
#2 |
holes drilled and hardware added to the switch panel housing
![]() CB pics ![]() ![]() ![]() here is a better mock up ![]() hooray for sheet metal ![]() using a 2x4 cut to the same diameter as the roll cage, i bent the mounting brackets for the front crossmember ![]() ![]() ![]() ![]() cont...
#3 |
brackets bolted to the crossmember ( c channel aluminum )
![]() ![]() now due to clearance for the bolts on the crossmember, i had to drill out the inner bracket and weld the nut right into the bracket and grind it down ![]() ribbed supports ![]() my cat helping me out making sure that the wires for my radio don't get tangled ![]() wiring mess....i fired the cat... ![]() clean stereo harness ![]() some of the metal stuff primed...the large sheet at the bottom is for the top of the console ![]() the console rocker guarded, more pics to follow soon!!! ![]()
#4 |
VERY nice.... i think i've been inspired...
i think an MDF model would be much cleaner.. nice work.. ![]()
THIS AIN'T YOUR MAMA'S STATION WAGON!! Built Jeep Tough With Chevy Stuff "Tater 2" '91 2 door XJ chopped and bobbed, 4.0, AW4, dana 300, GM 60/70HD, 40" IROKs on H1s SEE THE BUILD HERE |
#5 |
any installed pics??
#6 |
Fabramicator
that looks really nice
My Build Thread Useful links: Stu-Offroad - great technical write-ups! What's a CV shaft and why do I need one? Driveline 101 TJ Specs -Mike-
#7 |
Looks great, please post some more pics!
#8 |
hey guys, thanks for the input. as for MDF, it would definitely be cleaner and easier to work with, but it is also fairly heavy.....plus i got the plywood for a grand total of 51 cents, and only used half of it. when i do a new center console i will probably go with mdf.
its not quite finished, so installed pics yet, but i should have another update by saturday Thanks again!
#9 |
looks great!
#10 |
#11 |
Jackstand Wheeler
sweet i'd make one if i didnt have the tuffy already.
#12 |
ΜΟΛΩΝ ΛΑΒΕ
that looks really good. too bad for the cat though.
'99 Gunmetal TJ Blue Jeep Club Member #256 4" RC X-Series, 1in BL Rokmen Armor KC Day Lighters, 33 BFG M/T with more to come OlllllllO |
#13 |
#14 |
Pics?
10char
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine |
#15 |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
