-   Fabrication Shop (http://www.jeepforum.com/forum/f37/)
-   -   TJ Overhead Console Build Thread (http://www.jeepforum.com/forum/f37/tj-overhead-console-build-thread-956806/)
FlyinPhil 01-25-2010 11:43 PM
Due to my lack of funds and Tuffy's overhead console being $400+, i decided to build my own console to house my stereo, cb, maxitrip auto comp., and a switch panel. Now i realize there will be some dispute about using plywood for the main body of the console, but i am a very adequate woodworker, so i decided to stick with what i know ( I didn't win the Construction student of the year award for doing nuthin' ! ). So the main issues i have heard with using wood for something like this are moisture and vibration. I used rocker guard over the whole thing, so moisture is not really an issue. Plus i gusseted (lol is that even a word??) quite will, so i dont think vibes will be a problem.
The design:
Due to my inability to plan stuff in advance, i came up with the overall design and layout of the console during a random stroll through home depot with one of my buddies. the idea seemed fairly solid, so i picked up most of the needed materials at that point.
The Materials:
One sheet of plywood ( got it from the scrap section for 51 cents )
one 1"x1/8"x48" steel bar. ( had to get another one later, so two were needed )
one 8' piece of 1/8" c-channel aluminum....lots will be left over. just need 44.5" for the front crossmember that goes between the cage bars.
a plethora of 1/4"x3/4"and1/2" bolts, with corresponding nuts and rubber washers for each
about 6-8 larger bolts (cant recall the size at the moment)
one 3'x2' sheet of galvanized steel (doesnt have to galvanized, but it was shiney.. )
some small screws, 1/2" i believe
lots of primer and paint
few cans of rocker guard
waterproof/outdoor glue
and a few other things i've probably forgotten but will add later.
In total this cost me just less than $150 ( the paint accounts for a fair bit of it ) not including the switches, stereo, wiring, etc.
Tools:
hammer
Assortment of saws: band saw, scroll saw, jig saw, hack saw are all good to have
Screwdrivers
Drill
Drill bit set....everything from 3/16s to 1/2" (for both metal and wood)......drill press would've been nice
a few files
marking awl
center punch
sandpaper
vice
anvil was nice to smooth the edge of the freshly cut sheet metal
tin snips
and again, i've probably forgotten something that i can add later
now, time for pictures
getting started
http://i540.photobucket.com/albums/g...onsole1066.jpg
planning stuff out
http://i540.photobucket.com/albums/g...onsole1068.jpg
cutting one of the sides
http://i540.photobucket.com/albums/g...onsole1070.jpg
the two identical sides next to each other
http://i540.photobucket.com/albums/g...onsole1071.jpg
The maxitrip
http://i540.photobucket.com/albums/g...onsole1072.jpg
a quick mock up of the stereo and computer
http://i540.photobucket.com/albums/g...onsole1074.jpg
Glueing.....the more clamps the better
http://i540.photobucket.com/albums/g...onsole1075.jpg
Deciding what to do for the switch panel
http://i540.photobucket.com/albums/g...onsole1076.jpg
I drilled 4 holes, one at each corner of where the switch panel housing had to be cut out.
http://i540.photobucket.com/albums/g...onsole1078.jpg
Mock up of the switch panel (though there will be 8 switches when it is done...one for the coffee maker, passenger ejection, oil slick....etc )
http://i540.photobucket.com/albums/g...onsole1080.jpg
cont....
FlyinPhil 01-25-2010 11:44 PM
holes drilled and hardware added to the switch panel housing
http://i540.photobucket.com/albums/g...onsole1082.jpg
CB pics
http://i540.photobucket.com/albums/g...onsole1083.jpg
http://i540.photobucket.com/albums/g...onsole1084.jpg
http://i540.photobucket.com/albums/g...onsole1085.jpg
here is a better mock up
http://i540.photobucket.com/albums/g...onsole1089.jpg
hooray for sheet metal
http://i540.photobucket.com/albums/g...onsole1091.jpg
using a 2x4 cut to the same diameter as the roll cage, i bent the mounting brackets for the front crossmember
http://i540.photobucket.com/albums/g...onsole1092.jpg
http://i540.photobucket.com/albums/g...onsole1100.jpg
http://i540.photobucket.com/albums/g...onsole1101.jpg
http://i540.photobucket.com/albums/g...onsole1102.jpg
cont...
brackets bolted to the crossmember ( c channel aluminum )
http://i540.photobucket.com/albums/g...onsole1104.jpg
http://i540.photobucket.com/albums/g...onsole1106.jpg
now due to clearance for the bolts on the crossmember, i had to drill out the inner bracket and weld the nut right into the bracket and grind it down
http://i540.photobucket.com/albums/g...onsole1118.jpg
ribbed supports
http://i540.photobucket.com/albums/g...onsole1107.jpg
my cat helping me out making sure that the wires for my radio don't get tangled
http://i540.photobucket.com/albums/g...onsole1108.jpg
wiring mess....i fired the cat...
http://i540.photobucket.com/albums/g...onsole1109.jpg
clean stereo harness
http://i540.photobucket.com/albums/g...onsole1110.jpg
some of the metal stuff primed...the large sheet at the bottom is for the top of the console
http://i540.photobucket.com/albums/g...onsole1111.jpg
the console rocker guarded, more pics to follow soon!!!
http://i540.photobucket.com/albums/g...onsole1114.jpg
DC4W-93XJ 01-26-2010 10:22 AM
VERY nice.... i think i've been inspired...
i think an MDF model would be much cleaner.. nice work..
:tea:
DC4W-93XJ 01-26-2010 10:23 AM
any installed pics??
MO2500 01-26-2010 10:43 AM
that looks really nice :thumbsup: installed pics please :D
5.7YJ 01-26-2010 10:56 AM
Looks great, please post some more pics!
FlyinPhil 01-26-2010 11:04 AM
hey guys, thanks for the input. as for MDF, it would definitely be cleaner and easier to work with, but it is also fairly heavy.....plus i got the plywood for a grand total of 51 cents, and only used half of it. when i do a new center console i will probably go with mdf.
its not quite finished, so installed pics yet, but i should have another update by saturday
Thanks again!
TennesseeTJ02 01-26-2010 11:05 AM
looks great!
FlyinPhil 01-26-2010 11:07 AM
Originally Posted by TennesseeTJ02 (Post 8766778)
looks great!
Thanks! there will be more pics soon :thumbsup:
Unii 01-29-2010 10:57 PM
sweet i'd make one if i didnt have the tuffy already.
JWitt333 01-30-2010 09:49 AM
that looks really good. too bad for the cat though.
bdevr 01-30-2010 07:07 PM
:tea:
Keep in mind that MDF and moisture do not get along well. MDF act like a sponge and will fall apart quickly if it gets wet.
DivineKaos 02-10-2010 07:53 PM
Pics?
10char
frenchlayer 02-11-2010 07:12 AM
feel free to send me the tuffy and then you can build away:2thumbsup:
The time now is 05:19 AM.
