TJ Mini Boat side rockers - Page 6 - JeepForum.com
post #76 of 90 Old 09-04-2012, 10:31 AM Thread Starter
cgmrdc
1988 MJ Comanche
Yeah I did, but have since sold the jeep. Most of these pics were pulled out of my build thread. That's still active so you can see the finished product in the link in my sig
cgmrdc is offline
post #77 of 90 Old 10-01-2012, 04:56 PM
TXST8tj
TXST8tj's Avatar
Do you recall what size of 3/16th sheet you started with? I am considering getting started with this project.
Patrick
TXST8tj is offline
post #78 of 90 Old 10-01-2012, 04:59 PM Thread Starter
cgmrdc
1988 MJ Comanche
a 4x8... i had a few projects in mind so i bought a full sheet
cgmrdc is offline
post #79 of 90 Old 10-01-2012, 05:00 PM Thread Starter
cgmrdc
1988 MJ Comanche
a 3x5 would be enough tho
cgmrdc is offline
post #80 of 90 Old 10-01-2012, 11:35 PM
TXST8tj
TXST8tj's Avatar
On the first page you showed that you cut the plate to allow you to bend the material. You then came back and welded it.
Rather than cutting through the steel and having to weld both sides back, would it work to just cut a 'relief' at the lines......cut enough to be able to bend it, but not enough to go through......and then only have to weld the inside seams to strengthen? I did that with my fair lead mount and it worked well, but that is not going to possibly support the Jeep like these might.
4x8 sounds good. I'm sure I can find something else to use the rest for. I'll have my guy see what kind of price I can get it for.
Patrick
TXST8tj is offline
post #81 of 90 Old 10-02-2012, 12:33 AM Thread Starter
cgmrdc
1988 MJ Comanche
I tried that on my belly up skid and I ended up spending a ton of time trying to relief cut the whole thing and it was no where near as long of a bend so I figured this would be even harder to do that way. Even with as much as I cut out it still took all my weight and 2 24 inch pipe wrenches to bend.
cgmrdc is offline
post #82 of 90 Old 10-02-2012, 03:08 PM
TXST8tj
TXST8tj's Avatar
Ok. Fair enough. That was the info I was looking for.
I just got pricing back for the steel......looks to be about $115 for a 4x8 sheet of 3/16". I had them price aluminum while they were at it....$425 for the same size sheet.
I am thinking $150 for material, hardware, and consumables would not be too bad. I would not be adding the tube steps; at least not for now.
Patrick
TXST8tj is offline
post #83 of 90 Old 10-07-2012, 10:07 PM
TechJeeper
I'm the current owner of the jeep these were built for and I was originally going to ditch the steps thinking they would get hung up on rocks but really helps keep the jeep from really wedging into stuff.
TechJeeper is offline
post #84 of 90 Old 11-16-2012, 10:32 AM
Kodiak17
Love this thread. Cant wait to get a welder and jump into the fab world.
Maintain, wheel, upgrade, repeat.
My build: http://www.jeepforum.com/forum/f22/thor-dd-weekend-warrior-1348534/
Kodiak17 is offline
post #85 of 90 Old 11-16-2012, 01:33 PM Thread Starter
cgmrdc
1988 MJ Comanche
Thanks!
cgmrdc is offline
post #86 of 90 Old 12-09-2012, 08:20 PM
Kodiak17
Would I be able to use nutserts instead of bolts and nuts? Seems harder with the backing plate and spacer underneath, then again, many companies use nutserts such as Savvy
Kodiak17 is offline
post #87 of 90 Old 12-10-2012, 08:59 AM
TechJeeper
I wouldn't trust nutserts IF you are wanting with a step likes these. For a straight rocker guard nutserts are fine on the places you can't get to. You can get to the back side of the rocker and through bolt very easy and it is way stronger. Large thick washers work well as backers for things like this. I didn't build these rocker guards but I currently own them and have built other ones before. Always through bolt were you can and nutserts can be a giant pain.
post #88 of 90 Old 12-10-2012, 09:21 AM
Kodiak17
I always thought of them as being more convenient when installed correctly. What makes this applicatiom different than regular washers? Asking not arguing here.
Kodiak17 is offline
post #89 of 90 Old 12-10-2012, 10:11 AM
TechJeeper
There's only an expanded lip on the back side that actually holds the nutsert in. In a blind spot they are very convenient but they aren't near as strong as a through bolt. So my advice is simple through bolt every place you can. Also if the threads on a nutsert ever seizes and it breaks loose from its grip in the sheet metal you'll never get another nutsert to grip that hole. If you insist on using some sort of nutsert use a plusnut. They aren't cheap but they expand on the back side of the sheet metal much like a drywall anchor but with 4 prongs so get a a good amount of mounting surface. They sell a cheesy version at ACE hardware but fastenal has them on their website you have to search around for them they aren't called plusnuts on fastenal.com. Also if they seize drill it out and you can install another in its place.
And just because SAVVY uses them doesn't mean they are the best solution.
post #90 of 90 Old 12-10-2012, 02:00 PM
Kodiak17
I understand, you make a good point, just trying to get some more input as I plan to tackle this in the next month.
Kodiak17 is offline
opinion on mini spools?? iwishihad1 General Jeep & Off-Road Equipment 6 09-05-2012 06:53 AM
Mini CB review... TRC-503 CrAlt Audio, CB & Ham Radios, GPS, & Electrical 8 03-17-2007 10:01 AM
Boat-side Rockers E_ROCK Fabrication Shop 42 01-17-2007 05:23 PM
Wiring An iPod Mini To My 00 TJ - HELP! omnipseudo Audio, CB & Ham Radios, GPS, & Electrical 4 12-20-2004 05:59 PM
Mini project - XJ / YJ NaeKid Fabrication Shop 12 05-06-2003 11:33 PM
